VAND AMPLIFICATOARE DLS CA23
Tibitzu
Data înscrierii: 16/Feb/2009
MesajTrimis: Vin Noi 04, 2011 12:28 am    Titlul subiectului: VAND AMPLIFICATOARE DLS CA23 Răspunde cu citat (quote)
Se vand doua amplificatoare DLS CA23.
Impecabile din orice punct de vedere 10/10.
Foarte puternice si sunet foarte placut.
Folosite in regim de SQ doar pe difuzoare.
Cumparate acum cateva luni.
Se vand in ambalajele originale cu toate acesoriile de la producator.
La cerere se fac poze din toate unghiurile.
Accept orice proba in orice conditii.
Motivul vanzarii este ca nu le mai folosesc.
CA 23 is a powerful amplifier with a power output of 2 x 135 Watts.
With a mono bridge-connection, it puts out all of 400 Watts, ideal for subwoofer use.
- Built-in low pass filter for subwoofers, variable between 50 and 500 Hz.
- High pass / subsonic filter 15 - 150 Hz
- Bass boost control from 25 Hz - 80 Hz, 0-18 dB.
- Built-in protection circuits shut down the amplifier in the event of overloads.
- High level input with automatic start.
- RMS output power @ 13,8 V, 20Hz - 20 kHz
Specifications
Number of channels 2
Amplifier class AB
Mono bridge mode 4 ohm 400 W RMS
Output power in 2 ohm 2 x 200 W RMS
Output power in 4 ohm 2 x 135 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance > 10 kohm
Input impedance, high level 100 ohm
High pass filter 15 - 150 Hz
Low pass filter 50 - 500 Hz
Grand bass filter 25 - 80 Hz, 0-18 dB
Low level output Yes
High level input with auto start Yes
Power consumption (idle) 0,7 A
Power consumption (max) 60 A
Rec. power cable Minimum 5AWG / 16 mm2
Dimension (W x D x H) 70 x 312 x 268 mm (2,92 x 12,28 x 10,55 inch)
Fuses 2 x 30 A
Weight 3,6 kg ( 7,9 lb)
PRET: 490 LEI ( PRET IN MAGAZIN 900 LEI )
TRIMIT IN TOATA TARA PRIN CURIER RAPID SAU POSTA ROMANA
DETALII AICI SAU PE PRIVAT
Tibitzu
MesajTrimis: Dum Noi 13, 2011 10:20 am    Titlul subiectului: Răspunde cu citat (quote)
sus cu ele...impecabile la cutie....
Tibitzu
MesajTrimis: Lun Noi 21, 2011 8:14 pm    Titlul subiectului: Răspunde cu citat (quote)
SUS CU ELE...CINE LE IA PE AMANDOUA ARE O MICA REDUCERE...SAU TRANSPORT GRATUIT
Tibitzu
MesajTrimis: Vin Dec 02, 2011 11:36 am    Titlul subiectului: Răspunde cu citat (quote)
SUS CU ELE,impecabile...CINE LE IA PE AMANDOUA ARE O MICA REDUCERE...SAU TRANSPORT GRATUIT
Tibitzu
MesajTrimis: Lun Dec 12, 2011 4:30 pm    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Lun Dec 26, 2011 8:04 pm    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Mie Ian 11, 2012 6:37 pm    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Dum Ian 22, 2012 8:08 pm    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Lun Ian 30, 2012 8:11 pm    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Vin Feb 10, 2012 1:15 am    Titlul subiectului: Răspunde cu citat (quote)
Tibitzu
MesajTrimis: Vin Feb 10, 2012 4:53 pm    Titlul subiectului: Răspunde cu citat (quote)
VANDUTE....multumesc...se poate inchide...
