fotografpasionat
Data înscrierii: 08/Oct/2011 Mesaje: 23
Trimis: Sâm Dec 08, 2012 12:32 am Titlul subiectului: vand subwoofer RE AUDIO XXX12 + ampl. HIFONICS GX4000D |
SUBWOOFER CA SI NOU. AM SI INCINTA PENTRU EL POZE LA CERERE.
INCINTA PENTRU MASINA CU PORTBAGAJ MARE, GOLF4, SAU ORICE ALTCEVA
DIMENSIUNI 84X56X38 CM
Built for Brutality
You’ve stumbled upon RE Audio’s XXX Subwoofer. Don’t be afraid. This subwoofer is built for brutality, but capable of so much more. This subwoofer competes with any high output SPL based subwoofer, but is capable of outputting amazing sound quality as well.
RE Audio knew this subwoofer was meant for those serious about the bass in their vehicles, and manufactured this subwoofer accordingly. With such a gigantic magnet, a new venting system had to be engineered; this Vented Magnet System (or VMS) allows the subwoofer to output amazing levels of power without getting too hot.
RE Audio’s XXX Subwoofer may intimidate some, however after getting to know the XXX Subwoofer, it has a kind side as well. One part of the RE Audio XXX Subwoofer completely boasts pure, unrivaled power handling, engineered primarily for excess. Another side of the XXX may surprise some, the subwoofer also sounds extremely clean and tightly responsive. RE Audio XXX Subwoofers are proudly manufactured in the USA, RE Audio truly cares about fine crafting their flagship subwoofers.
Subwoofer Features:
12" Dual 2 ohm XXX Series Car Subwoofer
Power Handling:
RMS: 2000 watts
Impedance: Dual 2 ohm
Kevlar reinforced kraft pulp, dual composite 2-piece cone
Rubber surround
Integrated tinsel leads
FEA Optimized motor structure
Dual progressive spiders
Integrated gasket
Tork-Tite terminals
3" 4-Layer aluminum flat wire voice coil
Split coil design
VMS Vented magnet system
Cast aluminum basket
Triple stacked magnets
Designed specifically for sealed or ported enclosures
Mounting Depth: 12-3/4"
Mounting Hole Diameter: 11-1/2"
Proudly made in the USA
Authorized Internet Dealer
1-year Manufacturer's warranty
XXX 12" T/S Parameters:
Electrical Q Value (Qes): 0.46
Mechanical Q Value (Qms): 3.29
Total Speaker Q Value (Qts): 0.404
Free Air Resonance (Fs): 21 Hz
Equivalent Compliance (Vas): 74 liters
One-Way, Linear Excursion (Xmax): 54 mm
Efficiency (SPL 1W/1m): 83.76 dB SPL
Effective Piston Area (Sd): 480 cm2
DC Resistance (Re): 4.2 ohm
Nominal Impedance (Znom): Dual 2 ohm
Thermal Power Handling (Pe): 2000 W
Force Factor (Bl): 18.16
amplificator
ARATA CA SI NOU. PUTERE REALA MARE DE TOT. NECESITA FIRE GROASE DUBLE
Amplificator monoblock high-end
Clasa D, tehnologie Ultra D-Class
Putere RMS:
1 x 1500W la 4 ohmi sau
1 x 2700W la 2 ohmi sau
1 x 4000W la 1 ohm
Filtru subsonic 10-150Hz
Filtru lowpass 35-250Hz
Extented Bass Control - Bass EQ 30-60Hz
Bass boost +18dB
Control faza 0-180 grade
2 porturi pentru telecomanda
Telecomanda inclusa
Tranzistori MOSFET HighSpeed
Randament 72.9%
Logo HIFONICS iluminat albastru
Capace laterale din aluminiu
6000 ron tot.
le vand pentru ca nu le folosesc . nu imi incap in masina ce o am..motiv pentru ca doresc sa fac pe cineva fericit sa se bucure de ele!
0769758989
toboalpha Audiofil
Trimis: Sâm Dec 08, 2012 1:12 am Titlul subiectului: |
super pret...poate vine mosu la careva
spor la vanzare _________________ BasuL si cu Toba MarE
julyo13 Audiofil
Data înscrierii: 09/Mar/2011 Mesaje: 875 Locație: Vatra Dornei
Trimis: Lun Dec 10, 2012 4:31 pm Titlul subiectului: |
BASS DE CALITATE...!!!!!!!!!! _________________ ATOMIC 1000.1 D+2 ROCKFORD FOSGATE HE 12'' |
basspasionat Pasionat
Data înscrierii: 18/Ian/2013 Mesaje: 87
Trimis: Vin Ian 18, 2013 1:06 am Titlul subiectului: pret nou 1000 de euro |
| pret de vacanta 1000 de euro |
Trimis: Mie Apr 17, 2013 11:33 pm Titlul subiectului: de vanzare |
| a inceput sezonul cand 3000 ron fiecare statia, sau subwooferul |
