Alpine cda 105 ri
BRares
Data înscrierii: 10/Feb/2014
MesajTrimis: Sâm Ian 26, 2019 3:11 pm    Titlul subiectului: Alpine cda 105 ri Răspunde cu citat (quote)
import Germania in stare perfecta de functionare
Se vinde complet
PRET 420 lei
TEL 0757668190,Se poate vedea proba in CLUJ
Trimit in tara cu fan courier
SPECIFICATII
Tuner
Memory Presets: Preset Stations (FM:12 / MW:6 / LW:6)
Auto Memory
Seek Mode: Local / DX Selection
RDS
RDS Functions: TA, TP, PTY, NEWS, RADIO TEXT
Bluetooth®
Built-In or Ready: Parrot Bluetooth® Ready
Connection: Alpine KCE-400BT Required. Features may differ between phone model and service providers.
Hands Free: Hands Free Calling
Phone Book: Phone Book Transfer
Streaming Music: Streaming Music Playback
Streaming Music Control: Streaming Music Control
Connection for iPod®
Connection Type: USB Connection
Connection: USB Cable Included
Source Type: Dedicated iPod® Source
Compatibility for iPod®: iPod® 5th generation, iPod® nano 1st/2nd/3rd/4th generation, iPod® classic, iPod® touch 1st/2nd generation
Works with iPhone: Works with iPhone
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Song Up / Down / Repeat
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Percentage Search: Percentage Search
Alphabet Search: Alphabet Search
Information Display: Artist, Song, Album
Easy Navigating: Quick Search
Disc Player
Disc Type: CD Player
Disc Playback Type: CD/CD-R/CD-RW
Music Playback: MP3/AAC/WMA Playback
DAC: Multi Bit
Zero data Mute: 0 Bit Mute
Digital Servo: Digital Servo
Sensor: Music Sensor Scan/Repea
Playback Control: Play/Pause/Forward/Backward
# M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
USB Media Connection
USB Connection: USB Cable Included
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
High Pass Filter: High Pass Filter Adjustment
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Width: Q Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Frequency Adjustment
Loudness: Loudness Feature
MultEQ: MultEQ Ready (PXA-H100 Required)
MediaXpander: MediaXpander Ready (PXA-H100 Required)
Time Correction: 6 Channel Time Correction Ready (PXA-H100 Required)
Equalizer: 7 Band Graphic / 5 Band Parametric Equalizer Ready (PXA-H100 Required)
Crossover: Crossover Ready (PXA-H100 Required)
CD Changer Control
M.I.X.: One/All (Shuffle)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Backward
Repeat: Song/Disc
General
Power Output: 4 x 50 W High Power Amplifier
CD Changer: CD Changer Control
Display: White LCD (5 x 9dot, x12)
Control Type: Rotary Encoder Knob
Face Color: Black
# Illumination Buttons: Green / Amber / Blue / Red Illuminated Buttons
PreOut: 3 PreOuts (2 V )
PreIn: Selectable Power Input 2 PreIn (Front / Rear)
Versatile Link: Auxiliary Input Versatile-Link Ready (Required KCA-410C)
AUX-In: Full Speed AUX + (Required KCE-237B) ⁄ Ai-NET AUX IN (Required KCA-235B)
# Steering Wheel Remote Control: Steering Wheel Remote Control Ready
OEM Sub-display: OEM Sub-display Ready
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Output
Remote Turn-On: Amplifier Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
Remote Control: Remote Control Ready
SPECIFICATIONS
Max Power Output Ratings
Max Power Output: 4 x 50 W
FM Tuner
Tuning Range: 87.5-108.0 MHz
Mono Usable Sensitivity: 0.7 µV
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
MW Tuner
Tuning Range: 531-1,602 kHz
Usable Sensitivity (IEC Standard): 25.1/28.0 (µV/dB)
Connection for USB
USB Requirements: 1.1/2.0
Max. Power Consumption: 500 mA
USB Class: Mass Storage
File System: FAT 12/16/32
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media™ Audio
AAC Decoding: ACC-LC format/m4a file
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5-20 k ±1 dB (Frequency Response may differ depending on the encoder software/bit rate)
Total Harmonic Distortion: 0.008% (at 1 kHz)
Dynamic Range: 95 dB (at 1 kHz)
Signal-to-Noise Ratio: 105 dB
Channel Separation: 85 dB (at 1 kHz)
Disc Player
Channel Separation (1kHz): 85dB
Dynamic Range (1kHz): 95 dB
Total Harmonic Distortion (THD): 0.008% (at 1 kHz)
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8 kHz
Audio Signal-to-Noise (S/N): 105 dB
Sound Tuning
Subwoofer Level Adjustment: 0 to 15
High Pass Filter: OFF/60/80/100Hz (Selectable)
Bass Level Control Range: ±14
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide)
Treble Level Control Range: ±14
Treble Center Frequency: 10/12.5/15/17.5kHz (Selectable)
Remote Control
Included/Ready: Ready
Model Number: RUE-4202
Battery Type: AAA Batteries (2 pcs.)
Dimension (W x H x D) mm: 42mm x 121mm x 23mm
Weight: 50 g
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178 mm x 50 mm x 160 mm
Nose Piece Size (W x H x D) mm: 170 mm x 46 mm x 24 mm
General
Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 2 V
Operating Temperature (°C): 60°C to -10°C
Maximum Mounting Angle: 35° from Horizontal
Weight: 1.6 kg
Recommended Accessories
KCE-400BT: Bluetooth® Interface
PXA-H100: IMPRINT Audio Processor
RUE-4202: Remote Control Unit
KCE-237B: Fullspeed to mini jack adapter
KCA-235B: Ai-NET to mini-jack interconnector
KCA-121B: Ai-NET AUX IN RCA
BRares
MesajTrimis: Lun Ian 28, 2019 8:34 am    Titlul subiectului: Răspunde cu citat (quote)
vandut
