ALPINE IVA-D106R + NVE-M300P +PXA-H700 +TCS-V430A
alpine_clarion
Data înscrierii: 21/Mai/2012
MesajTrimis: Vin Mai 25, 2012 6:30 am    Titlul subiectului: ALPINE IVA-D106R + NVE-M300P +PXA-H700 +TCS-V430A Răspunde cu citat (quote)
Vand ALPINE IVA-D106R + ALPINE NVE-M300P + ALPINE PXA-H700 / 701 + ALPINE TCS-V430A in perfecta stare de functionare.
Item Description:
Alpine Navigation Pack:
Alpine IVA-D106R DVD CD/MP3 Tuner 7" Motorised Screen
Alpine NVE-M300P navigation unit
Alpine IVA-D106R Features:
Display: 7.0" Wide QVGA Display
Control Type: Rotary Encoder Knob
iPersonalize: Wall Paper Download
Face Color: Black
Illumination Buttons: Blue/Red
PreOut: 3 PreOut
PreIn: 2 PreIn (Front/Rear)
AUX-In A/V Input: 1, Camera-In (Dedicated), Full Speed AUX-In
AUX-Out A/V Output:1
DVB-T: DVB-T Ready
Steering Wheel Control Ready
Detachable Face Plate
Dimmer: Auto Dimmer
Power Antenna Output
Amplifier Remote Turn-On Output
Audio Interrupt Input
Remote Control Ready
IVA-D106R Tuner:
Preset Stations (FM:18/MW:6/LW:6)
RDS Functions
TA, TP, PTY, NEWS, T.INFO, RADIO TEXT
IVA-D106R BluetoothĆž:
Bluetooth Ready
Alpine KCE-300BT Required. Features may differ between phone model and service providers.
Hands Free Calling, Voice Dial Function
Phone Book Transfer
Streaming Music Playback
Streaming Music Control
IVA-D106R Connection for iPodĆž:
Full Speed Connection for iPodĆž (KCE-422i optional)
Connection: Full Speed Video Cable (KCE-430iV optional)
iPod Compatibility: All iPod Products with Dock Connector
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer
Video Capability: Video Playlist, Movie, Music Video, Video Podcast
Percentage Search: Percentage Search
Information Display: Artist, Song, Album
IVA-D106R Disc Player:
Disc Type: DVD Player
Disc Playback Type: DVD-Video, DVD-Audio, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-VR, VCD, CD, CD-R, CD-RW
File Playback: MP3/AAC/WMA/DivX Playback
DAC: 24-Bit DAC
IVA-D106R Sound Tuning:
Subwoofer Level Adjustment
Bass Center Frequency Adjustment
EQ Width Adjustment
Bass Level Adjustment
Treble Center Frequency Adjustment
Treble Level Adjustment
High Pass Filter Adjustment
MediaXpander: ready
Time Correction: ready
Equalizer: ready
Crossover: ready
MultEQ: IMPRINT ready
IVA-D106R CD-Changer Control
M.I.X.: One/All (Shuffle)
Music Text Information: CD: Text Scroll Display, MP3: Text Information Display (ID3 Tag)
IVA-D106R Specifications:
Power Requirement 14.4 V DC (11–16 V allowable)
Operating temperature 0°C to +45°C
Maximum Power Output 50 W × 4
Output Voltage 2V/10k ohms
Bass ± 14 dB at 100 Hz
Treble ± 14 dB at 10 kHz
Weight 2.6 kg
Audio output level Preout (Front, Rear): 2V/10k ohms (max.)
Preout (Subwoofer): 2V/10k ohms (max.)
AUX OUT: 1.3V/10k ohms
Ai-NET: 850 mV
Chassis Size
Width 178 mm
Height 50 mm
Depth 165 mm
FM Tuner Section:
Tuning Range 87.5 – 108.0 MHz
Mono Usable Sensitivity 9.3 dBf (0.7 µV/75 ohms) 50 dB
Quieting Sensitivity 13.5 dBf (1.1 µV/75 ohms)
Alternate Channel Selectivity 80 dB
Signal-to-Noise Ratio 65 dB
Stereo Separation 35 dB Capture Ratio 2.0 dB
MW Tuner Section:
Tuning Range 531 – 1,602 kHz Sensitivity (IEC Standard) 22.5 µV/27 dBf
LW Tuner Section
Tuning Range 153 – 281 kHz Sensitivity (IEC Standard) 31.6 µV/30 dBf
CD/DVD Section:
Frequency Response 5 – 20,000 Hz
Wow & Flutter (% WRMS) Below measurable limits
Total Harmonic Distortion 0.008% (at 1 kHz)
Dynamic Range 95 dB (at 1 kHz) Channel Separation 85 dB (at 1 kHz)
Signal system NTSC/PAL
Horizontal resolution 500 lines or greater
Video output level 1Vp-p (75 ohms)
Video S/N ratio DVD: 60 dB
Audio S/N ratio More than 105 dB
Monitor Section:
Screen Size LCD: 7.0"
Type Operation System: Transparent type TN LCD TFT active matrix
Number of Picture Elements: 336,960 pixels (1440 × 234)
Alpine NVE-M300P Navigation Features:
New User Interface with consistent structure for easy operation
SIRF Titan Processor for super fast start up, route calculation and re-route
Auto Zoom to let you easily recognise your manoeuvre
Integrated High end TMC receiver – plus KAE-500FM antenna option
Turn-by-turn guidance
Easy guidance with Text-to-Speech (TTS) announcing street names
Lane guidance display
Route simulation mode
Seamless scaling and overview mode for long distance routes
Daytime and night time colour profiles
2D and real 3D map display with hundreds of 3D landmark icons
Track Logs function to record and export the track you drive
Road safety cameras pre-installed for various countries where legal
Increased map coverage, especially for Eastern European countries with latest maps available
Personal POI (Point Of Interest) import
7-digit UK postcode search
Easy installation, no speed pulse connection required. Positioning via GPS
Underpass and Overpass information
Our take on the Alpine PXA-H701
by Matt Freeman
There's nothing like the cozy confines of a car to emphasize the thrilling dynamics of surround sound, and Alpine's PXA-H701 audio processor can help you experience the impact of multichannel sound in your vehicle.
The processor features three optical digital inputs, so you can connect each of your digital video sources with just one cable. The processor decodes the DolbyĆž Digital or DTSĆž signal from your DVDs and sends it to the external amplifiers that power your front, rear, and center-channel speakers, plus your subwoofer. The PXA-H701 even translates your stereo CDs into vivid multichannel sound.
If you're using the PXA-H701 with a compatible Alpine in-dash DVD player, you can use the player's touchscreen controls to adjust the system. If you're using the processor with an outboard DVD player or a non-Alpine in-dash player, you'll need an optional Alpine controller to make system adjustments.
No center-channel speaker in your car? The processor can create a "phantom" center for you, so you hear the dialog in the middle, where the center channel normally would be. The processor also includes digital time correction, graphic and parametric equalizers, frequency filters, and MediaXpander — sonic enhancement features that help you get your movies and music sounding just right in your vehicle.
Highlights:
mobile surround sound processor
decodes 5.1 Dolby Digital and DTS signals
Dolby Pro Logic II (applies multichannel processing to stereo sources)
front, rear, center, and subwoofer preamp outputs
two RCA audio inputs
navigation sound input
Ai-Net input for connecting a compatible Alpine component such as a DVD player
Alpine CD changer input
digital time alignment for optimizing the sound in specific listening positions
graphic equalizer — 31 bands for front, rear, and center; 10 bands for subwoofer
7-band parametric equalizer
active crossover system maximizes speaker performance
MediaXpander adds fullness to your sound
3-step bass compensation
phantom center channel simulates center effects if no speaker is present
warranty: 1 year
Product Overview: The Alpine PXA-H701 Multimedia Manager allows you to add multi-channel music and movie soundtracks with digital sound processing to virtually any system. It can be controlled by the IVA-D310, DVA-9965, and DVA-9860 head units, or used as a stand-alone system with the RUX-C701 controller (sold separately). The PXA-H701 offers Dolby Digital and DTS decoding, and allows you to connect up to three source components via optical digital inputs. In addition, you can make multiple audio adjustments using the built-in graphic and parametric equalizers and digital time alignment.
Digital-to-Analog Converters: The unit is equipped with eight 26kHz/24dB MDACs (multi-level digital-to-analog converters).
Digital Time Alignment: You can perform digital time alignment to correct the time errors caused by the major differences in the distances between the vehicle's speakers and a particular listening position. Time correction can be adjusted manually by measuring the distances to each speaker and applying time correction values to each speaker. Audible time correction can be made from 0.05 ms to 20.00 ms in 0.05ms steps. You can also perform time correction automatically when the optional RUX-C701 control unit and the microphone included with the controller are used.
Graphic Equalizer: The built-in graphic equalizer allows you to modify the sound to suit your taste using 31 bands each for the front (left and right), rear (left and right), and center speakers. Adjustable frequencies are 20Hz to 20kHz in 1/3 octave steps. An additional 10 bands are available for the subwoofer from 20Hz to 160Hz in 1/3 octave steps. Levels are adjustable +/- 9dB in steps of 1dB.
Parametric Equalizer: For correcting undesired peaks and dips at specific frequencies not affected by the graphic equalizer's fixed frequency bands, you can use the built-in 11-band parametric equalizer and tune to those frequencies. Five frequency bands can be adjusted for the front (left and right), rear (left and right), center, and two bands for the subwoofer. Levels can be adjusted +/- 9dB in steps of 1dB, and the band width (Q) can be adjusted in 6 steps of 0.5, 1, 2, 3, 4 or 5. Selectable frequencies include:
Front, Rear, and Center:
Band 1: 20Hz to 500Hz (29 steps)
Band 2: 50Hz to 1.2kHz (29 steps)
Band 3: 125Hz to 3.2kHz (29 steps)
Band 4: 315Hz to 8kHz (29 steps)
Band 5: 800Hz to 20kHz (29 steps)
Subwoofer:
Band 1: 20Hz to 80Hz (13 steps)
Band 2: 50Hz to 200Hz (13 steps)
Active Crossover: The PXA-H701 is equipped with an active crossover, allowing the frequency bands to be split before amplification. You can activate two low pass and high pass filters for the front, and one each for the rear, center, and subwoofer. The front and rear crossovers can have different adjustment values for the left and right channels, if desired. All crossovers have a selectable slope of 6, 12, 18, 24, or 30dB/octave, or can be turned off independently. Crossover frequencies include:
Front 1: (select Tweeter or Full Range)
Tweeter:
High Pass: 1kHz to 18kHz (cannot be set to "Off")
Low Pass: 1.1kHz to 20kHz
Full Range:
High Pass: 20Hz to 18kHz
Low Pass: 22Hz to 20kHz
Front 2:
Rear:
Center:
Subwoofer:
High Pass: 20Hz to 180Hz
Low Pass: 22Hz to 200Hz (cannot be set to "Off")
Media Xpander (MX): The Media Xpander makes vocals or instruments sound distinct regardless of the music source. You can set an MX effect level for each connected source.
Bass Compensation: Bass Comp can be activated to accentuate bass frequencies. You can choose any of three levels of Bass Comp to suit your tastes.
Surround Features
Dolby Digital/DTS: The PXA-H701 can decode 5.1-channel Dolby Digital and DTS signals from a connected DVD player and output these discrete signals to the appropriate output jacks for front left, front right, rear left, rear right, center, and subwoofer preamp outputs.
Dolby Pro Logic II: You can apply Dolby Pro Logic II processing on any 2-channel music or movie signal from a CD, DVD, FM or Satellite Radio. You can select Dolby Pro Logic II Music to enhance stereo music recordings, or Dolby Pro Logic II Movie to simulate 5.1 channel surround sound. In addition, you can choose a Rear Fill function for 2-channel Dolby Digital and DTS signals and output the front channel signals to the rear speakers.
Speaker Setup: The PXA-H701 lets you adjust the output according to the playable frequency range of your speakers. You can designate the size of each set of speakers as "small" or "large" based on their ability to play sounds at 80Hz or lower, and set the subwoofer for "on" or "off". The level for each speaker (front left and right, rear left and right, and center) can be set in a range of +/-10dB, either manually or automatically.
Phantom Center: If you do not have a designated center channel speaker, the unit can distribute the center channel audio information to the front left and right channels. This creates a simulated or "phantom" center speaker directly in front of each listener. The level of this acoustic center image can be adjusted within a range of -5 to +5, allowing you to shift the image from one side to the other.
Standard/Maximum Sound: Dolby Digital are compressed to achieve powerful sound at regular volume levels. This compression can be canceled so you can achieve an even more powerful sound at high volume levels. You can choose Standard or Maximum listening modes to suit the level you desire.
DVD Levels: You can independently set the output levels for DVDs for Dolby Digital, DTS, Dolby Pro Logic II, and PCM.
Inputs and Outputs
Left Side of Unit:
RCA Outputs: 4 pairs of RCA jacks for Front 1 (tweeter or full range) L/R, Front 2 L/R, Rear L/R, Center and Subwoofer
Control Unit: Round 13-pin DIN jack for connecting optional RUX-C701 control unit
Mic: 3.5mm female mini-jack for microphone (supplied with RUX-C701 control unit)
Optical Inputs: 3 TosLink optical digital inputs (with plastic protective plugs) for CD/DVD Head Unit, Changer, and DVD
RCA Input: 3 female RCA jacks for left and right audio and "guide" (navigation audio input)
Ai-NET In: Ai-NET jack for connecting compatible Ai-NET component such as a DVD player
Changer In: Ai-NET jack for connecting Ai-NET CD changer
Power Supply: 6-wire Molex jack for supplied power harness
Specifications
Specifications:
Frequency Response: 10 Hz to 24 kHz
Signal-to-Noise Ratio: 100 dB
Channel Separation: 80 dB
Input Sensitivity: 850 mV (2V for Analog 1 only)
Rated Output: 4 V (with a 10 kOhm load)
pret 1000 euro (fix)
tel: 0751488830 sau YM alpine_clarion@yahoo.com
otzy
Data înscrierii: 14/Feb/2007
Locație: timisoara
MesajTrimis: Vin Mai 25, 2012 11:55 pm    Titlul subiectului: Răspunde cu citat (quote)
pret pe componente?
alpine_clarion
MesajTrimis: Sâm Mai 26, 2012 8:06 am    Titlul subiectului: Răspunde cu citat (quote)
otzy a scris:
pret pe componente?
-Alpine IVA-D106R DVD CD/MP3 Tuner 7" Motorised Screen - 1500 roni
-Alpine NVE-M300P navigation unit - 1200 roni
-Alpine Tuner TV TCS-V430A - 500 roni
-Alpine procesor PXA-H701 - 1000 roni
poze reale aici: http://forum.4tuning.ro/560-pachete-audio-statie-hu-difuzoare-etc/318089-audio-video-alpine-audison-helix-infinity-rockford.html#post5038401
