edy
Data înscrierii: 17/Iun/2014 Mesaje: 24
Trimis: Dum Iul 20, 2014 8:26 pm Titlul subiectului: Amplificator DLS Ultimate A3 1000w |
Number of channels 2
Amplifier class AB
Output power in 1 ohm 2 x 425 W RMS
Output power in 2 ohm 2 x 270 W RMS
Output power in 4 ohm 2 x 150 W RMS
Mono bridge mode 4 ohm 550 W RMS
Mono bridge mode 2 ohm 870 W RMS
Mono bridge mode 1.33 ohm 1000 W RMS
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
Low level output No
External cooling fan terminal Yes
Dual DC inputs Yes
Remote bass level control No
Remote phase shift control No
High level input with auto start No
Integrated fan No
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
EAN Bar code 7331644024507
Pret 300 euro. 0767 458 322 |
