liviu_nyc
Data înscrierii: 08/Sep/2011 Mesaje: 19 Locație: Constanta
Trimis: Vin Ian 10, 2014 6:43 pm Titlul subiectului: De vanzare un subwoofer Phase Linear Aliante SI 12 inch |
Perfect functional,fara interventii.
Specificatii:
DIN diameter: 300 mm
Lower cut-off frequency: 19 Hz
Upper cut-off frequency: 300 Hz
Nominal power handling: 400 watts
Maximum load: 900 Watt
Impedance: 4 Ohm
Sensitivity: 90 dB
Fs: 20 Hz
Vas: 133 l
Qts: 0, 29
Special features: Polished steel pole plate, flow-optimized rear ventilation, isolated input terminals low installation depth Anthrazithfarbener aluminum die cast basket aluminum lined Honeycombmembrane
Pret: 600 Ron
Tel : 0724369395
Trimit prin posta sau curier oriunde in tara. |
liviu_nyc
Trimis: Joi Ian 23, 2014 5:44 pm Titlul subiectului: |
Anunt valabil ptr urechi fine  |
