un necunoscator
Data înscrierii: 08/Dec/2006 Mesaje: 29
Trimis: Vin Dec 12, 2008 5:32 pm Titlul subiectului: [DECODARE] Panasonic CQ-VD6503N |
salut
am un dvd player 2din Panasonic CQ-VD6503N care il am pe masina, problema este ca eu am luat masina cu tot cu dvd si nu am niciun manual la el, recent am scos bateria de pe masina iar acum imi cere un cod de siguranta, pe care nu il am, iar fostul proprietar al masinii nu si-l aminteste.
Se poate face ceva, decodare/resetare/resoftare?? daca DA...UNDE??? _________________ nu rade de cineva cand face un pas inapoi, s-ar putea sa isi ia avant! |
un necunoscator
Trimis: Mar Dec 16, 2008 4:03 pm Titlul subiectului: |
chiar nimeni?? _________________ nu rade de cineva cand face un pas inapoi, s-ar putea sa isi ia avant! |
Body28 Audiofil
Trimis: Mie Dec 17, 2008 12:05 am Titlul subiectului: |
M-am uitat putin pe net dupa manual si ideea e ca nu am gasit decat ca nu se poate reseta..
"How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until “COMPLETED!” is displayed.
The ID code cancelling procedure is completed.
The unit now works without an ID code.
Note:
¡Should your unit ever require service, cancel your ID
code before sending for repair.
¡The ID code setting cannot be eliminated even by the
memory clear function.
¡The inputted code is not displayed for your security.
0 9
Caution
¡Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to
use the unit. In case you forget the ID code,
please consult your nearest Panasonic
Servicenter."
http://service.us.panasonic.com/OPERMANPDF/CQVD6503U-MULTI.PDF
Pagina 32. Si totusi... el tine in memorie codul chiar daca nu are curent.. s-ar putea sa aiba o baterie mica inauntru. Un electronist te-ar putea ajuta. Dar sa fie unul bun totusi. |
un necunoscator
Trimis: Mie Dec 17, 2008 2:01 am Titlul subiectului: |
faza de 2 lei este ca nici la panasonic la service (call center) nu au reusit sa ma ajute
sunt ferm convins ca utilajul ar putea fi resoftat _________________ nu rade de cineva cand face un pas inapoi, s-ar putea sa isi ia avant! |
Body28 Audiofil
Trimis: Mie Dec 17, 2008 12:15 pm Titlul subiectului: |
Am gasit foarte putine chestii despre el pe net (aproape nimic chiar). Nu are multa lume Panasonic-ul asta. Ai putea incerca sa-l tii o sapt, 2 fara alimentare.. Nu prea ai solutii. Asta sau faza cu electronistul. |
un necunoscator
Trimis: Mie Dec 17, 2008 12:56 pm Titlul subiectului: |
masina a stat ceva luni fara baterie...
iar acum il tin in portbagaj pana gasesc o solutie  _________________ nu rade de cineva cand face un pas inapoi, s-ar putea sa isi ia avant! |
un necunoscator
Trimis: Dum Dec 28, 2008 1:26 am Titlul subiectului: |
intr-un final am rezolvat problema
am fost la alarm service (service panasonic) si a fost decodat/resoftat
damage la buzunar: 150 roni
cam scump dupa parerea mea, dar macar acum am si eu la ce sa ascult muzica _________________ nu rade de cineva cand face un pas inapoi, s-ar putea sa isi ia avant! |
