Ayrun
Data înscrierii: 11/Iul/2007 Mesaje: 11 Locație: 183
Trimis: Joi Ian 05, 2012 10:32 am Titlul subiectului: PACHET RECEIVER PIONEER VSX 418+ DVD DV 490 V K + INCINTE MM |
VAND PACHET RECEIVER PIONEER VSX 418+ DVD DV 490 V K + INCINTE MM
1. RECEIVER AV PIONEER VSX 418K
SpecificationsConstruction VSX-418-K
DSP design Advanced Digital Core Engine
Pioneer Hybrid Amplification Yes
Digital Signal Processor Freescale 180 MIPS Processing DSP
Amplifier Specifications VSX-418-S
D/A Converter 192 kHz / 24-bit
Tuner Specifications VSX-418-K
Radio Data System (RDS) Yes
Usable Sensitivity (Mono) 13,2 dB
Sensitivity Mono 20,2 dB
Sensitivity Stereo 38,6 dB
Signal-to-Noise Ratio Mono (DIN) 73 dB
Signal-to-Noise Ratio Stereo (DIN) 70 dB
Stereo Separation at 1 kHz 40 dB
Input & Output connections VSX-418-S
Front Mini Jack Yes
Audio/Video Output Yes
Composite Input/Output 3/1
Digital Audio Input 3 (assign)
Digital Optical Input/Output 1/-
Digital Coaxial Input/Output 2
Large speaker terminals Front : Large , Other (Clips)
Multi-Channel Input 5.1 ch
Speaker A/B Yes, A only
Audio Features VSX-418-K
Auto Level Control Yes
Auto Surround Yes
Bass/Treble Tone Controls Yes
Loudness Yes
Midnight Listening Mode Yes
Phase Control Yes
Sound Retriever Yes
Stream Direct Yes
Virtual Surround Back Yes
Main Features VSX-418-K
Output Power per Channel 130W
Impedance at Output Level 8Ω
Number of Channels 5
Signal / Noise Ratio 88 / 64 db
Input Connections 3 x composite, 1 x digital optical, 2 x digital coaxial, 5.1 x multi-channel (DVD)
Output Connections 1 x composite
Tuner Pre-set Stations 30
Remote Control Glow-key preset remote control
Power Consumption (in use / standby) 280W / 0,5W
Weight 7,9 kg
Dimensions (W x H x D) 420 x 158 x 348 mm
Surround Sound Formats VSX-418-S
Dolby Digital Yes
Dolby Pro Logic II Yes
DTS Yes
DTS 96/24 Yes
WMA 9 Pro Yes
Surround Modes 12+2
Power Output VSX-418-K
Power output per channel 110W
Condition 1 kHz, 1%THD, 8Ω
Rated Power Output 130W per channel
Input (Sensitivity/Imp.): LINE 335 mV / 47 kΩ
Frequency Response: LINE 5 Hz to 100 000 Hz
Signal-to-Noise Ratio: LINE (DIN) 88 /64 dB
Power Requirements AC 220 - 230V, 50/60Hz
Construction VSX-418-S
Direct Construction Yes
2. DVD Player with HDMI Output (Black) PIONEER DV490K
citeste:
DVD Video
DVD-R
DVD-R DL
DVD-RW
DVD-RW DL
DVD+R
DVD+RW
SVCD
VCD
CD
CD-R
CD-RW
WMA
MP3
JPEG
DivX
HDMI (High Definition Multimedia Interface)
convertor D/A: 96KHz/24bit
moduri DSP: Rock, Pop, Live, Dance, Techno, Classic, Soft
convertor video D/A: 108MHz/12-bit
sistem: PAL / NTSC
PureCinema Progressive Scan: PAL/NTSC
distorsiuni: 0,0023 %
raspuns in frecventa: 4 - 44.000HZ
raport semnal/zgomot: 115dB
3. PERECHE BOXE MAGNAT MONITOR 1000
Boxa floorstanding 3 cai *putere RMS: 170W *putere Max: 360W *impedanta: 4-8 ohmi *sensibilitate (1W/1m): 92dB *raspuns in frecventa: 19Hz - 35KHz *frecventa crossover: --- / 3500Hz *tip incinta: bass-reflex *diametru woofer: 2 x 17cm *dimensiuni: 210mm x 950mm x 320mm *culori disponibile: cherry, black, beech *pachetul contine DOUA BUCATI
PRET PACHET 1000 RON
NU AU NICIO DEFECTIUNE, POT FI PROBATE SI ASCULTATE |
