BRares Priceput
Data înscrierii: 10/Feb/2014 Mesaje: 399
Trimis: Sâm Noi 17, 2018 8:12 am Titlul subiectului: Radio CD Alpine CDE-178BT |
import Germania
stare perfecta ca nou
se vinde complet ,fara cutie
proba in Cluj
PRET 700 lei FIX
tel 0757668190
https://www.olx.ro/oferta/radio-cd-alpine-cde-178bt-sony-jvc-kenwood-IDbLw2U.html
Features
Tuner
Memory Presets: Preset Stations (FM:18, MW:6, LW:6)
Memory: Auto Memory
Seek Mode: Local/DX Selection
RDS
RDS Functions: TA, TP, AF, PTY, News, Radio Text
BLUETOOTH®
Built-in BLUETOOTH® Module
Hands Free Calling: HFP (Hands Free Profile) or HSP (Head Set Profile) Compatible Phones
Streaming Music: A2DP (Advanced Audio Distribution Profile) Compatible
Streaming Music Control: AVRCP (Audio/Video Remote Control Profile) Ver.1.4 Compatible
BT Plus Advanced BLUETOOTH Technology
Connection: SSP (Secure Simple Pairing) Supported
Phone Book: Phone Book Synchronization
Phone Book Search: 3 Letters Alphabet Search
Speed Dial: 6 Pre-set Memory
Multiple Phone Number Registration: 4 Phone Number Registration Possibility
Phone Book Label Display: Mobile, Home, Work, Other
Voice Dial Operation: Voice Control for iPhone Supported
Auto Answer
Call Waiting
Call History Display: Dialled Call, Received Call, Missed Call
Speech Volume Level Adjustment: Adjustable for Outgoing and Incoming Volume
Hands-Free Phone Sound Setting: 5 Type Selection
Signal Strength Indicator
Battery Level Indicator
Output Speaker Selection
Menu Language Selection: English, German, French, Italian, Spanish, Dutch, Russian
Firmware Updatable
Microphone Included
Made for iPod® / iPhone®
Compatibility for iPod/iPhone: Made for iPod touch 4th/3rd/2nd/1st Gen., iPod nano 6th/5th/4th/3rd/2nd/1st Gen., iPod classic 160GB/120GB/80GB, iPhone 4S, iPhone 4, iPhone 3GS, iPhone 3G and iPhone
Connection: KCU-442i (sold separately) Required
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook, Genius Mix
Alphabet Search
Percentage Search
vTuner Internet Radio: vTuner for Alpine Compatible
"vTuner pentru Alpine" nu este Ăźn prezent disponibil Ăźn iTunes store.
App Direct Mode
Direct Up/Down: Playlist, Artist, Album, Genre, Composer, Episode Up/Down
M.I.X. (Shuffle) Play: Song, Album, All
Repeat
Battery Charging
Alpine TuneIt App
Sound Setting Function
Sound Setting Data Upload to Alpine Cloud Server (Data Sharing)
Facebook Notification
Compatible for iPhone and Android Smartphones: Available on Apple App Store and Google Play Store
Disc Player
Disc Type: CD Player
Disc Playback Type: CD, CD-R/RW
Music Playback: CDDA, MP3, WMA, AAC Playback
M.I.X. Random Play: Track/Folder, All
Repeat
CD Text Display
CD Text Name Search
Percentage Search
USB Media Connection
USB Connection: Rear USB Connection
(USB Cable Included)
Music Playback: MP3, WMA, AAC File Playback
USB Class: Mass Storage Class
File/Folder Name Search
Folder Up/Down
M.I.X. Random Play: Folder, All
Repeat
Sound Tuning
Bass Engine™ Pro:
Subwoofer Level Adjustment
Subwoofer Phase Select
Subwoofer System Select
4Volt PreOut
Equalizer: Flat, Pops, Rock, News, Jazz, Electrical Dance, Hip Hop, Easy Listening, Country and Classical
9-band Parametric Equalizer
Digital Time Correction
Digital Crossover Setting
Application Volume Level Setting
MediaXpander
Power IC Management System
General
Power Output: 4 x 50W High Power Amplifier
Display: High Resolution LCD Display
White LED Backlighting System
Illumination Buttons: 4 Illumination Colour Selectable (Blue/Green/Red/Amber)
High Grade Audiophile Design
3 PreOuts (4V, Front + Rear + Subwoofer)
DAC: 24-bit DAC
AUX-In: Rear AUX Input (3.5mm mini jack)
Steering Wheel Remote Control Ready
OEM Sub-display Ready
Menu Language: English, German, French, Italian, Spanish, Dutch, Russian
Clock / Calendar
Firmware Updatable
Detachable DIN Trim Plate
Detachable Face Plate
Dimmer
Power Antenna Lead
Remote Turn-On
vTuner
Start-Stop Engine unaffected
Specifications
Max Power Output Ratings
Max Power Output: 4 x 50W
FM Tuner
Tuning Range: 87.5 - 108.0 MHz
Mono Usable Sensitivity: 0.7 μV
Alternate Channel Selectivity: 80 dB
Signal-to-Noise Ratio: 65 dB
Stereo Separation: 35 dB
Capture Ratio: 2 dB
MW Tuner
Tuning Range: 531 - 1,602 kHz
Usable Sensitivity (IEC Standard): 25.1 μV / 28 dB
LW Tuner
Tuning Range: 153 - 281 kHz
Usable Sensitivity (IEC Standard): 31.6 μV / 30 dB
Disc Player
Frequency Response: 5 - 20k Hz (±1 dB)
Total Harmonic Distortion (at 1kHz): 0.008 %
Dynamic Range (at 1kHz): 95 dB
Signal-to-Noise Ratio: 105 dB
Channel Separation (at 1kHz): 85 dB
Wow & Flutter (%WRMS): B.M.L.
USB
USB Requirements: USB 1.1/2.0
Max. Power Consumption: 1,000 mA
File System: FAT 12/16/32
MP3 Decoding: MPEG Audio Layer-3
WMA Decoding: Windows Media™ Audio
AAC Decoding: AAC-LC Format ′′.m4a′′ File
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5 - 20k Hz (±1 dB) *May differ depending on the encoding software and bit rate.
BLUETOOTH®
BLUETOOTH® Version : Bluetooth v2.1 + EDR
Output Power: +4 dBm Max. (Power Class 2)
HFP: Hands Free Profile
HSP: Head Set Profile
A2DP: Advanced Audio Distribution Profile
AVRCP: Audio/Video Remote Control Profile v1.4
Sound Tuning
Subwoofer Level Adjustment: 0 to 15 dB
Subwoofer Phase Setting: 0° or 180°
Bass Level Control Range: ±9.1 dB at 100Hz
Treble Level Control Range: ±9.1 dB at 10 kHz
Time Correction: 0.0 to 336.6cm (3.4cm step)
Parametric Equalizer (Band 1): 20 - 100 Hz
Parametric Equalizer (Band 2): 63 - 315 Hz
Parametric Equalizer (Band 3): 125 - 500 Hz
Parametric Equalizer (Band 4): 250 - 1k Hz
Parametric Equalizer (Band 5): 500 - 2k Hz
Parametric Equalizer (Band 6): 1k - 4k Hz
Parametric Equalizer (Band 7): 2k - 7.2k Hz
Parametric Equalizer (Band : 5.8k - 12k Hz
Parametric Equalizer (Band 9): 9k - 20k Hz
Parametric Equalizer (Gain): -7 to +7 dB
Parametric Equalizer (Bandwidth): 3, 4, 5
Crossover Frequency: HPF + LPF 20, 25, 31.5, 40, 50, 63, 80, 100, 125, 160, 200 Hz
Crossover Slope: Flat, 6, 12, 18, 24 dB/oct.
Crossover Gain: -12 to 0 dB
Application Volume Level Setting: ±14 dB
General
Power Requirement: 14.4 V.DC (11-16V allowable)
Pre Output Voltage (Before Clipping): 4V / 10k ohms
Aux In: 1.4V / 10k ohms
Maximum Mounting Angle: 35°
Weight: 1.5 kg
Dimensions
Din Size: 1 DIN
Chassis Size (W x H x D) mm: 178 x 50 x 162 mm
Nose Piece Size (W x H x D) mm: 168 x 45 x 24 mm |
BRares Priceput
Trimis: Dum Noi 18, 2018 8:32 am Titlul subiectului: |
| se negociaza la 640 lei + taxe transport suportate de cumparator |
BRares Priceput
BRares Priceput
Trimis: Sâm Noi 24, 2018 6:37 am Titlul subiectului: |
| oferta ---450 lei fara negocieri |
BRares Priceput
Trimis: Dum Dec 02, 2018 9:46 pm Titlul subiectului: |
se vinde si la 400 lei
aduc si alte modele alpine la cerere |
BRares Priceput
Trimis: Lun Dec 03, 2018 6:51 am Titlul subiectului: |
| rezervat |
BRares Priceput
Trimis: Lun Dec 03, 2018 5:46 pm Titlul subiectului: |
vandut
valabil alpine 117 ri |
BRares Priceput
Trimis: Mie Dec 05, 2018 7:51 pm Titlul subiectului: |
| vandut si 117 ri |
