soundstream di 475
shoboolan
Data înscrierii: 26/Dec/2014
MesajTrimis: Vin Dec 26, 2014 10:55 pm    Titlul subiectului: soundstream di 475 Răspunde cu citat (quote)
Salutare! Ma ajutati si pe mine in alegerea unui subwoofer pentru amplificatorul sounstream di475 ? sa caut pe 4 ohm sau pe 2 ohm ?
Soundstream Di475.1
SPECIFICATII AMP:
475W, Class D Monoblock Amplifier (Di 475.1)
* Extreme Bass Machine Single-Channel Class D2 Car Amplifier
* RMS Power Rating:
o 4 ohms: 350 watts x 1 chan.
o 2 ohms: 475 watts x 1 chan.
* PWM MOSFET power supply
* Wired remote bass level control included
* LED power indicator
* Selectable bass boost (0, 6, 12 dB @ 45 Hz)
* 3 Stage protection circuit
* Single channel operation
* Speaker-level inputs with signal sensing for automatic turn-on)
* 1 Set of preamp RCA outputs
* SMD Technology
* Mil-Spec fiberglass circuit board
* True digital switching
* High rail voltage
* Compact chassis and design
* 18dB Crossover centered at 80 Hz
* Heavy duty aluminum alloy heatsink for heat dissipation
* Nickel-plated RCA level inputs
* Nickel-plated screw terminals
* Frequency response: 50-150 Hz
* Dimensions: 11-3/4"L x 8-3/4"W x 2-1/8"H
Razvy_Zeus
Data înscrierii: 10/Mai/2007
MesajTrimis: Mar Dec 30, 2014 8:26 pm    Titlul subiectului: Răspunde cu citat (quote)
Cel mai bine este sa cauti un subwoofer pe 2 ohmi sau care sa permita legarea la 2 ohmi. Cam in ce buget vrei sa te incadreazi ?
