cosmin777967
Data înscrierii: 04/Mai/2011 Mesaje: 9
Trimis: Sâm Mai 23, 2015 9:22 pm Titlul subiectului: Vand Alpine PXA H700 |
Vand procesorul de sunet ALPINE PXA-H70 in stare foarte buna de functionare , folosit de aproximativ 1 luna , cumparat din state . Este compatibil cu majoritatea unitatilor Alpine cu AI-NET .Vine la cutie cu toate accesoriile originale si cablu optic de 5m , pret fix 1100 ron, nu ma intereseaza schimburi .
Specificati :
Decodes 5.1 Dolby Digital and DTS signals
Dolby Pro Logic II (applies multichannel processing to stereo sources)
three optical digital inputs
front, rear, center, and subwoofer preamp outputs
two RCA audio inputs
navigation sound input
Ai-Net input for connecting a compatible Alpine component such as a DVD player
Alpine CD changer input
digital time alignment for optimizing the sound in specific listening positions
graphic equalizer — 31 bands for front, rear, and center (155 bands) ;
2way/3way/4wat/5.1
10 bands for subwoofer
7-band parametric equalizer
active crossover system maximizes speaker performance
MediaXpander adds fullness to your sound
3-step bass compensation
phantom center channel simulates center effects if no speaker is present
PRET : 1100 LEI FIX si nu ma intereseaza schimburi.
Digital-to-Analog Converters: The unit is equipped with eight 26kHz/24dB MDACs (multi-level digital-to-analog converters).
Digital Time Alignment: You can perform digital time alignment to correct the time errors caused by the major differences in the distances between the vehicle's speakers and a particular listening position. Time correction can be adjusted manually by measuring the distances to each speaker and applying time correction values to each speaker. Audible time correction can be made from 0.05 ms to 20.00 ms in 0.05ms steps. You can also perform time correction automatically when the optional RUX-C700 control unit and the microphone included with the controller are used.
Graphic Equalizer: The built-in graphic equalizer allows you to modify the sound to suit your taste using 31 bands each for the front (left and right), rear (left and right), and center speakers. Adjustable frequencies are 20Hz to 20kHz in 1/3 octave steps. An additional 10 bands are available for the subwoofer from 20Hz to 160Hz in 1/3 octave steps. Levels are adjustable +/- 9dB in steps of 1dB.
Parametric Equalizer: For correcting undesired peaks and dips at specific frequencies not affected by the graphic equalizer's fixed frequency bands, you can use the built-in 11-band parametric equalizer and tune to those frequencies. Five frequency bands can be adjusted for the front (left and right), rear (left and right), center, and two bands for the subwoofer. Levels can be adjusted +/- 9dB in steps of 1dB, and the band width (Q) can be adjusted in 6 steps of 0.5, 1, 2, 3, 4 or 5. Selectable frequencies include:
Front, Rear, and Center:
Band 1: 20Hz to 500Hz (29 steps)
Band 2: 50Hz to 1.2kHz (29 steps)
Band 3: 125Hz to 3.2kHz (29 steps)
Band 4: 315Hz to 8kHz (29 steps)
Band 5: 800Hz to 20kHz (29 steps)
Subwoofer:
Band 1: 20Hz to 80Hz (13 steps)
Band 2: 50Hz to 200Hz (13 steps)
Active Crossover: The PXA-H700 is equipped with an active crossover, allowing the frequency bands to be split before amplification. You can activate two low pass and high pass filters for the front, and one each for the rear, center, and subwoofer. The front and rear crossovers can have different adjustment values for the left and right channels, if desired. All crossovers have a selectable slope of 6, 12, 18, 24, or 30dB/octave, or can be turned off independently. Crossover frequencies include:
Front 1: (select Tweeter or Full Range)
Tweeter:
High Pass: 1kHz to 18kHz (cannot be set to "Off")
Low Pass: 1.1kHz to 20kHz
Full Range:
High Pass: 20Hz to 18kHz
Low Pass: 22Hz to 20kHz
Front 2:
Rear:
cosmin777967
Trimis: Lun Sep 28, 2015 9:06 am Titlul subiectului: |
| Se poate inchide, s-a vandut . |
