gaby0007 Pasionat
Data înscrierii: 24/Iun/2011 Mesaje: 72 Locație: Bucuresti
Trimis: Joi Iul 25, 2013 1:35 pm Titlul subiectului: Vand amplificator,cd player,tuner radio,deck,tw peerless |
1-amplificator de casa,Denon PMA-920,Stare tehnica: 9.5/10, Stare Optica: 8/10
Speakers : A, B, A + B front switching
-:®:- Power rating x 2 : 105W RMS at 8 ohms, 180W at 4 ohms
-:®:- Dynamic power : 270W at 4ohms, 350W at 2ohms
-:®:- Total harmonic distortion : 0.004%
-:®:- Optical class A circuit design, dual mono contruction
-:®:- Source Direct : for tone controls bypass
-:®:- Phono : MM moving magnet and MC moving coil options front switching
-:®:- Dimensions [ W x H x D ] : 434 x 162 x 392mm
-:®:- Weight : 11.0kg - packed 13kg
Pret:500 lei
2-cd player Denon DCD-660 (uneori citeste greu discurile, e posibil sa necesite curatarea lentilei, se vinde ca atare)
Audio Characteristics
Channels : 2 Channels
Sampling frequency: 44.1 kHz
D/A conversion: 20-bit LAMBDA super linear
Oversampling: 8 times
Frequency range: 2Hz - 20kHz
Dynamic range: > 98dB
S/N ratio: >107dB
Channel separation: >100dB @ 1 kHz
THD: >0.003% at 1kHz
Analog output: 0.2 - 2V RMS. 2 x RCA phono
Headphone output: ¼" jack with level control
Power requirements: 230 VAC 50/60Hz
Power consumption: 10 Watts
Dimensions: 435(w) x 97(h) x 276 (d) mm
Net Weight: 4.1 Kg
Pret:100 lei
3-Set Technics deck RS-E10+cd player SL-E10.Stare optica 8/10,stare technica 9/10.
Pret:150 lei
4-tuner pioneer f-550 rds,Stare tehnica: 10/10, Stare optica: 8.5/10
pret:200 lei
5-Set tweetere Peerless Vifa XT25TG30-04. Stare tehnica: 10/10. Stare optica: 8/10 (10 fiind nou in cutie).
Parametrii si detalii tehnice:
http://www.madisoundspeakerstore.com/ring-radiator-tweeters/vifa-xt25tg30-04-1-ring-radiator-tweeter/
Pret: 200 RON |
gaby0007 Pasionat
Trimis: Joi Iul 25, 2013 1:38 pm Titlul subiectului: |
