Vand amplificator Cougar pe 6 canale 3000W
zanga_style
Data înscrierii: 25/Noi/2010
Locație: bucuresti
MesajTrimis: Joi Noi 25, 2010 10:45 pm    Titlul subiectului: Vand amplificator Cougar pe 6 canale 3000W Răspunde cu citat (quote)
Descriere :
Insane 6 Channel Mosfet design amplifier for connecting multiple speakers, from Cougar. 3000 Watt – let the games begin. Bridgeable at 6/5/4/3/2 channels.
The latest amplifier from the boys at Cougar outdoes itself with 3000W max power – made possible through modern Mosfet technology and 6 roaring channels. With power to spare and well thought out features, this amplifier transforms you car into a force to be reckoned with. As always, Cougar excels at more than just the technical aspects, taking the amps design to the next level. Amplifier with cross over network and volume control. New optics and new Carbu technology. Stable at 2 Ohm in stereo mode.
Highlights:
6 channel Mosfet Power Amplifier
Powerful 3000 Watt Max at 4 Ohm
4 x 500 watt + 1 x 1000 watt = 5 channels
6/5/4/3 Channel operation
Bridgeable
Modern Mosfet Technology
High and Low pass filter
Features:
3 RCA inputs (RCA connections)
Cross over network and volume control
With Tri-Mode connection
Frequency response: 20 Hz to 20 kHz
Signal to noise ratio: 74 dB (unfiltered)
High pass filter: 50 to 250 Hz
Low pass filter: 120 Hz to 3 kHz
Input sensitivity: 250 mV
Input impedance: 47 kOhm
Output last: 2-8 Ohm (Stereo) 4-8 Ohm (Mono)
Output impedance: 4 Ohm
Protection: 2 x 20 Ampere
Cross over point
Power supply: 10 to 14 V
On and off direct over radio
Included:
Amplifier
Spare fuse
Dimensions:
355 x 252 x 52mm
Weight: 6.8 kg
Amplificatorul se prezinta intr-o stare impecabila, nu prezinta urme de uzura, pus pe masina de 3 luni, el fiind cumparat nou!
Este montat pe masina amplificand 2 sisteme de difuzoare si se poate face proba!
Ofer si cer maxima seriozitate!
Contact : 0731633266-Cristi
Pret : 250lei
zanga_style
Locație: bucuresti
MesajTrimis: Mar Noi 30, 2010 11:45 pm    Titlul subiectului: Răspunde cu citat (quote)
s-a dat!se poate inchide, multumesc be-loud pt gazduire!!!
