Samyaza
Data înscrierii: 14/Mai/2017 Mesaje: 8 Locație: Galati
Trimis: Mar Dec 25, 2018 4:40 am Titlul subiectului: Vand Amplificator Helix Dark Blue 4 |
Amplificator Helix Dark Blue 4 x 70W RMS, 2 x 174 W in punte 4Ohm.
Sonic 10/10 aspect fizic 7/10
Output power RMS / max.
- 4 Ohms 4 x 65 / 130 Watts
- 2 Ohms 4 x 90 / 180 Watts
- 1 Ohm -
- bridged 4 Ohms 2 x 180 / 360 Watts
- bridged 2 Ohms -
Amplifier technology Class AB
Inputs 4 x RCA / Cinch
4 x Highlevel speaker input
1 x Remote In
1 x Remote control input
Input sensitivity RCA / Cinch 0.5 - 6 Volts
Highlevel 1 - 14 Volts
Input impedance RCA / Cinch 30 kOhms
Input impedance highlevel 12 Ohms
Outputs 4 x Speaker output
Output voltage RCA / Cinch -
Signal converter for digital input -
Frequency response 10 Hz - 50.000 Hz
Bass boost 0 - 12 dB / 45 Hz
Highpass 15 Hz - 4,000 Hz adjustable
Lowpass 40 Hz - 4,000 Hz adjustable
Bandpass 15 Hz - 4,000 Hz adjustable
Subsonic -
Phase -
Slope high- / lowpass 12 dB/Oct.
Slope subsonic / lowpass -
Signal-to-noise ratio digital input -
Signal-to-noise ratio analog input 108 dB (A-weighted)
Distortion (THD) 0.02 %
Damping factor 65
Operating voltage 9.6 - 16 Volts
Idle current 1000 mA
Fuse 2 x 25 A Maxi-fuse (APX)
Additional features Active, adjustable crossover, bass boost, input mode switch, highlevel input with automatic turn on function and Advanced Diagnostics Error Protection (ADEP), optional cable remote control
Pret: 350 RON
Tel: 0759430571 sau mesaj aici pe forum
George _________________ Everything dies. |
