vand amplificator JL Audio E1200
adyxzz
Data înscrierii: 12/Mai/2013
MesajTrimis: Mie Mar 11, 2015 1:35 am    Titlul subiectului: vand amplificator JL Audio E1200 Răspunde cu citat (quote)
vand amplificator clasa AB JL Audio E1200, monobloc, este al unui prieten are tot la el, cutie originala, poze reale la cerere, se trimite prin ce doreste cumparatorul, acesta fiind achitat de cumparatorul, specificatii
Class AB Monoblock Full Range Amplifier
Patented Absolute Symmetry dual N-Channel MOSFET output design
Pass-through RCA outputs
State-variable, 12dB/Oct Butterworth crossover with continously variable cutoff frequency selection from 50 - 200Hz.
Configurable as High or Low pass Filter
High level inputs
CEA-2006 Compliant
RMS Power Rating:
200 watts x 1 chan. at 2 Ohms
120 watts x 1 chan. at 4 Ohms
Frequency Response: 10Hz - 25kHz
Damping Factor: >200 @ 4 Ohms / 50Hz
Slew Rate: +- 22V/us
Input Range: 200mV - 8V RMS
Bass Boost: 0 - 6dB (0 - 18dB with Bass remote - Not Included)
Dimensions: 9.8" L x 9.25" W x 2.36" H
pret 500ron info pe pm, sau la 0745086800
adyxzz
MesajTrimis: Mie Mar 11, 2015 3:14 pm    Titlul subiectului: sal Răspunde cu citat (quote)
poza nu e reala doar info
