Sugar20 Priceput
Data înscrierii: 19/Iun/2010 Mesaje: 411 Locație: Timis
Trimis: Sâm Feb 07, 2015 4:06 pm Titlul subiectului: Vand amplificator monobloc Massive Audio D3600 |
Massive Audio D 3600 Digital Block Series Mono Car Amplifier
RMS Power Rating:
4 ohms: 650 watts x 1 chan.
2 ohms: 950 watts x 1 chan.
1 ohm: 1800 watts x 1 chan.
Max power output: 3600 watts
MOSFET power supply with high grade switching devices
LED power/protect indicators
Brushed aluminum "finless" heat sink
Short circuit, thermal, reverse voltage, and over voltage protection
Linkable with single RCA for easy upgrade
N-channel circuity for high efficiency
Illuminated Log
Frequency response: 10-220Hz
THD (Total Harmonic Distortion): .2%/li>
Signal-to-Noise Ratio: >70 dB
Low pass variable crossovers 40-220Hz
Sub sonic filer: 10-50Hz
Bass boost frequency: 30-80Hz
Max Voltage: 15V
Overheat temperature protection: 80°C/176F
Max RCA Voltage: 5V
CEA-2006 compliant amplifier
Weight: 15 lbs
Dimensions: 14-13/16"L x 6-1/2"W x 2-1/8"H
Amplificatorul este NOU in cutie cu toate accesoriile!
Pret: 1200 lei
Tel: 0765 792 145
 _________________ " If it's too loud...
You're too old ! " |
Sugar20 Priceput
Trimis: Dum Feb 15, 2015 7:28 pm Titlul subiectului: |
Up!! _________________ " If it's too loud...
Sugar20 Priceput
Trimis: Joi Feb 19, 2015 6:01 pm Titlul subiectului: |
Up!!! _________________ " If it's too loud...
Sugar20 Priceput
Trimis: Mar Feb 24, 2015 9:05 pm Titlul subiectului: |
Up!!!!! _________________ " If it's too loud...
