vand amplificator Rockford Fosgate punch p200 -2
alexD
Data înscrierii: 09/Apr/2008
MesajTrimis: Joi Apr 29, 2010 6:20 pm    Titlul subiectului: vand amplificator Rockford Fosgate punch p200 -2 Răspunde cu citat (quote)
Amplificator Rockford Fosgate punch p200 -2 in stare buna optic 9 din 10.
Pret : 700 ron usor discutabil . Nu accept schimburi. 0724853549
Specificatii :
Number of Channels 2
Rated Power
continuous power 50W x 2 @ 4-Ohms RMS
100W x 2 @ 2-Ohms RMS
200W x 1 @ 4-Ohms bridged RMS
Total Power
total sum of 'rated power' 200 Watts
Dynamic Power
powercube measurement (info) 74 Watts x 2 @ 4-Ohms 0° Res
131 Watts x 2 @ 2-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 68% @ 4-Ohm
62% @ 2-Ohm
Crossover Controls High-Pass (HP): 50Hz-500Hz 12dB/octave Butterworth
Low-Pass (LP): 50-500Hz 12dB/octave Butterworth
Tone Controls Punch EQ2 Bass: 0dB to +18dB @ 45Hz and/or
Punch EQ2 Treble: 0dB to +12dB @ 12kHz
Function depends upon LP/AP/HP switch position
Signal Input Low level: 1 RCA pair
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional PEQ Remote Punch EQ
(overrides built-in Punch EQ2)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1.0dB
Shipping Weight 6.34 Lbs.
(2.87 Kg.)
Dimensions (HxWxL) 2.25 x 7.625 x 9.0 (in)
5.71 x 19.37 x 22.80 (cm)
alexD
MesajTrimis: Dum Mai 02, 2010 2:18 pm    Titlul subiectului: Răspunde cu citat (quote)
sus cu ele.............
alexD
MesajTrimis: Lun Mai 10, 2010 10:43 am    Titlul subiectului: Răspunde cu citat (quote)
sus cu ele .Pretul usor negociabil
alexD
MesajTrimis: Mar Aug 17, 2010 12:08 pm    Titlul subiectului: Răspunde cu citat (quote)
pret nou 650 ron
