Marius_FTU Pasionat
Data înscrierii: 04/Apr/2008 Mesaje: 86 Locație: Bucuresti
Trimis: Joi Iun 16, 2016 4:00 pm Titlul subiectului: Vand amplificator Taramps HD3000 |
Descriere:
Number of Channels - 01
Max. Output Power @ 13,8 VDC - 1 OHM: 3598W RMS
Max. Output Power @ 13,8 VDC - 2 OHMS: 2446W RMS
Max. Output Power @ 13,8 VDC - 4 OHMS: 1403W RMS
Max. Output Power @ 12,6 VDC - 1 OHM: 3000W RMS
Max. Output Power @ 12,6 VDC - 2 OHMS: 2040W RMS
Max. Output Power @ 12,6 VDC - 4 OHMS: 1170W RMS
Input Sensitivity: 250mV @ -9,78 dBm
Total Harmonic Distortion (THD) 0,3%
Signal / Noise Ratio: >95dB
Damping Factor: 300
Frequency Response (Full Range): 5Hz to 15KHz
Crossover:
H.P.F (High Pass Filter): 5Hz to 50Hz (-12dB / Octave) Variable
L.P.F (Low Pass Filter): 50Hz to 15KHz (-12dB / Octave) Variable
Bass Boost: 0 to 10dB (50Hz)
Input Impedance: 18K OHMS
Protection System: Short into Output / Power Supply High/Low
Minimum Supply Voltage: 10,5 VDC
Maximum Supply Voltage: 16 VDC
Idle Consumption: 1,70 Amp.
Musical Maximum Consumption @ 12,6VDC: 170 Amp.
Sinusoidal Signal Maximum Consumption @ 12,6 VDC: 340 Amp.
Dimensions (WxHxD): 229 x 65 x 288mm
Weight: 3,11Kg
Functioneaza si arata impecabil, accept orice proba. Trimit si in tara.
Pret: 1600 RON negociabil
Pentru alte detalii: 0755 092 758 |
Marius_FTU Pasionat
Trimis: Dum Aug 07, 2016 4:18 pm Titlul subiectului: |
| UP! Inca valabil/negociabil. |
