racing_d10
Data înscrierii: 30/Noi/2006 Mesaje: 12
Trimis: Mar Ian 15, 2008 3:54 pm Titlul subiectului: vand AUDISON SRX 3 + subwoofer RE audio RE12 sealed |
Vand subwoofer RE AUDIO RE12 in incinta sealed
Specificatii:12”-30cm
Electrical Q Value -Qes: 0.42
Mechanical Q Value -Qms: 4.27
Total Speaker Q Value -Qts: 0.38
Free Air Resonance -Fs: 20.0 Hz
Equivalent Compliance -Vas: 182 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 87.3 dB SPL
Effective Piston Area -Sd: 500 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
Difuzorul se afla in stare foarte buna, nu are niciun defect.
www.reaudio.com
http://www.realmofexcursion.com/brands/reaudio.htm
Pret 500 RON
Vand amplificator Audison SRX3 in stare impecabila, castigator al premiului EISA AWARDS.
Specificatii:
* 3 Channel Output
* 2 Ohm Stable in stereo & mono
* High Level Speaker Input
* High Pass Crossover
* Low Pass Crossover
* RCA Input
* RMS Power outputs:
* 2 x 75 + 1 x 250 Watt at 4-ohms
* 2 x 65 + 1 x 340 Watt at 4/2 ohms
* 2 x 110 + 1 x 220 Watt at 2/4 ohms
* 2 x 95 + 1 x 315 Watt at 2-ohms
http://www.caraudio-store.de/SRx3,2x110,1x220,Watt,3,Kanal-Endstufe,Audison::::6073::::aed8e84f.html
pret: 750 RON
tel : 0724 933 903 _________________ bass addicted |
