Sharkky Audiofil
Trimis: Joi Apr 11, 2013 2:37 pm Titlul subiectului: [VAND] Componente Car-audio |
In urma unei curatenii amanuntite prin debara, se pun la vanzare urmatoarele componente audio:
Amplificator Genesis 3 Series - 5 Channel (4 x 50W @ 4 ohmi + 1 x 200W @ 2 ohmi)
Specificatii:
Power Source [Volts] - 10.8 ~ 14.4
Number of Channels - 5
Rated Power @ 14.4v [4 Ohm] - 4 x 50 + 1 x 200
Watts RMS @ 0.1% - Rated [2 Ohm] - 4 x 70 + 1 x 300
All Channels Driven - Rated [Bridge 4 Ohm] - 2 x 160 + 1 x 300
Typical Power @ 14.4v [4 Ohm] - 4 x 55 + 1 x 210
Watts RMS @ 0.1% - Typical [2 Ohm] - 4 x 80 + 1 x 310
All Channels Driven - Typical [Bridge 4 Ohm] - 2 x 160 + 1 x 380
Maximum Current Draw - 80 Amps
Signal to Noise Ratio 'A' Wtd [4 Ohm] - >100dB
THD + Noise @ Rated Output - 0.1%
Input Sensitivity [Volts RMS] - 0.3 ~ 5
Frequency Response - 20 Hz ~ 20 KHz
Dimensions H x W x D [mm]* - 62 x 450 x 210
Weight [Kg] - 5.7
Pret: 600 Euro
Subwoofer Peerless XXL 12" - 830877
Specificatii puteti gasi aici: http://www.tymphany.com/files/resources/dpeerless/830877.pdf
Pret: 150 Euro
CD Player Deck Pioneer DEX-P99R
Nu citeste MP3, nu are amplificare interna (este doar deck).
Specificatiile nu-si au rostul, cunoscatorii stiu despre ce e vorba.
Pret: 500 Lei
MP3 Alpine CDA-9835 (amplificarea interna nu functioneaza, doar preout-urile)
Specificatii:
26W x 4 V-Drive™ Amplifier
Bass Engine® Pro
- 6-Channel Digital Time Correction
- 6-Position HP/LP Digital Crossover
- 5-Band Parametric EQ
- Subwoofer Level Control with Phase Selector
- 3-Way or 2-Way Digital Crossover
Media Xpander™
SAT Radio Ready
MP3/WMA/CD-R/RW Playback
CD Text and MP3/WMA Tag Informtation Display
2-Line Color Display
Quick Search Function
CD Text, CD Text Display, CD Text Scroll
Versatile-Link™ Ready
MaxTune SQ Tuner
BlackOut Display
Regulated 1Bit DAC
3 PreOuts (4 volt)
iPod™ Interface Ready (KCA-420i)
MM Driver (Hard Disc Drive) Ready
MobileHub™ Ready
i-Personalize
Swing Mechanism with Detachable Face
Telecomanda inclusa
Pret: 500 Lei
Incinta Bass Reflex pentru difuzor de 30 cm (12")
Dimensiuni: L 56 x l 38 x h 35 cm
Pret: 100 Lei
Nu accept schimburi.
Voi reveni cu poze si pentru celelalte produse. |
Sharkky Audiofil
Trimis: Mar Sep 03, 2013 12:56 pm Titlul subiectului: |
| Valabil! |
Sharkky Audiofil
Trimis: Mar Oct 08, 2013 9:16 am Titlul subiectului: |
| Valabil! |
Sharkky Audiofil
Trimis: Mie Mar 12, 2014 10:59 am Titlul subiectului: |
| Valabil! |
asan_radu
Data înscrierii: 19/Iun/2011 Mesaje: 19
Trimis: Joi Iul 17, 2014 6:41 pm Titlul subiectului: |
| Tot valabil? Daca da te rog sa faci un update preturilor. Merci! |
