Vand DD3512, PXA-H800, Ru-C800,Alpine MRD-M1005
ELNA
Data înscrierii: 06/Aug/2006
MesajTrimis: Lun Noi 26, 2012 6:16 pm    Titlul subiectului: Vand DD3512, PXA-H800, Ru-C800,Alpine MRD-M1005 Răspunde cu citat (quote)
DD3512 Difuzorul este aproape ca nou cu exceptia unei singure probleme cand l-am cumparat cel care l-a trimis spre mine in ciuda insistentelor mele de a il monta pe un inel de MDF sau ma rog o placa de mdf pur si simplu l-a aruncat intr-o cutie cu 2 ziare si l-a trimis spre mine astfel a ajuns cu sasiul fisurat, l-am lipit cu o rasina epoxy si merge impecabil de 1 an ...
difuzorul arata si merge ca nou doar acel mic defect ...
pret 200E
Amplificatoru are si DSP cu corectie de timp , LP,Hp , Phase etc . Indicator de temperatura , voltaj , merge si la 1ohm pe proba
pret 200E
Class D mono subwoofer car amplifier
RMS Power Rating:
500 watts x 1 chan. at 4 ohms
1000 watts x 1 chan. at 2 ohms
Internal, variable-speed cooling fan
Amp Link for single-cable hookup to compatible Alpine receivers
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
Selectable subsonic filter (off, 15Hz, or 30 Hz)
Parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition
Top-mounted digital control center with cover
CEA-2006 Compliant
MOSFET power supply and output stages
Preamp outputs
Time correction 0-10 milliseconds in 0.1ms steps
Phase adjustment 0-180°
Turn-on delay
4-gauge power and ground leads
Extra-large terminals
Dimensions: 13" L x 8-11/16" W x 2-5/16" H
salut, se vinde acest procesor impreuna cu controleru aferent folosit 6 luni cred amandoua arata ca noi nu au nici un fel de defecte pachet complet cu totate cablurile inclusiv cel ai-net de 5m cutiile originale tot...
ultimul update de firmware facut etc.
mai jos e linkul cu procesoru...
http://www.youtube.com/watch?v=HDcGMjT_IUI
Graphic Equalizer: 31 Bands (Front, Rear, Center), 10 Bands (Subwoofer)
Parametric Equalizer: 10 Bands (Front, Rear, Center), 5 Bands (Subwoofer)
Crossover Adjustment : Highpass, Lowpass, Bandpass
8-channel Time Correction
ImprintEQ with 3 preset and fully customizable target curves
RoadEQ
Auto Time Correction (Auto TCR)
Dolby Digital
Dolby Pro Logic II
dts Digital Surround
Bi-Phantom Function
MediaXpander Plus
Euphony
AUX IN Gain Adjustment
AUX Output Level Adjustment
Navigation Voice Mix Level Adjustment
General
Ai-NET Connection
Number of Input Channel: 6 (Analog - RCA or Speaker Level), 2 (Optical Digital), 2 (Ai-NET)
Type of Analog Input: RCA (Speaker Line Connection Adapter Bundled)
Type of Digital Input: TOSLINK
Navigation Voice Guidance Input: RCA Input on Power Supply Connector
Number of Output Channel: 8 (RCA Output)
24-bit Ultra High Performance DAC
24-bit ADC
Twin 32-bit Floating-point Processing DSP
Extremely Low Jitter Management Circuit
4V Preout
S.T.A.R. Circuit
High Grade Audio Component Adopted
Gold-plated Terminals
PC Control Possibility for Sound Tuning Functions (Software Bundled)
Microphone Bundled
USB Cable Bundled
Ai-NET Connection Cable Bundled (5.5m)
SPECIFICATIONS
Sound Tuning
Graphic Equalizer Number of Bands: 31 Bands (Front, Rear, Center), 10 Bands (Subwoofer)
Graphic Equalizer Level Adjustment: ±12 dB (0.5dB step)
Parametric Equalizer Number of Band: 10 Bands (Front, Rear, Center), 5 Bands (Subwoofer)
Parametric Equalizer Frequency: 20/22/25/28/31.5/36/40/45/50/56/63/71/80/90/100/110/125/140/160/180/200/220/250/280/315/360/400/450/500/560/630/710/800/900/1k/1.1k/1.2k/1.4k/1.6k/1.8k/2k/2.2k/2.5k/2.8k/3.2k/3.6k/4k/4.5k/5k/5.6k/6.3k/7.1k/8k/9k/10k/11k/12.5k/14k/16k/18k/20kHz (Front, Rear, Center)
Parametric Equalizer Frequency: 20/22/25/28/31.5/36/40/45/50/56/63/71/80/90/100/110/125/140/160/180/200Hz (Subwoofer)
Parametric Equalizer Level Adjustment: ±12 dB (0.5dB step)
QFactor: 0.5; 1; 1.5; 2; 2.5; 3; 4; 5
Time Correction: 0 to 20ms (0.05ms step)
Crossover Frequency: 60 step (0 to -36 dB/oct.)
Dimensions
Chassis Size (W x H x D): 169 x 50.8 x 215 mm
General
Power Requirement: 14.4 (11-16) V.DC
Frequency Response: 20Hz - 20kHz
Signal to Noise Ratio (RCA Analog Input): >103dB (IHF-A)
Signal to Noise Ratio (Digital Input): >110dB (IHF-A)
Channel Separation: 90dB
Input Sensitivity (RCA Input): 2V
Input Sensitivity (Speaker Level Input): 7V
Rated Output: 4V (with 10k ohms load)
Distortion Factor: 0.01%
Input Impedance: 10k ohms or higher
Output Impedance: 1k ohms or less
Operating Temperature: -20°C to +60°C
Weight: 1.35kg
mai multe gasiti pe net ...
pretul este de 2600ron
schimburi poate cu un laptop plus diferenta
preturile sunt negociabile ...
BMW E90
Genesis Profile 2 Ultra x2
logic 7 200mm woofers
inca lucram !
ELNA
MesajTrimis: Mar Dec 04, 2012 1:43 pm    Titlul subiectului: Răspunde cu citat (quote)
upp!
BMW E90
inca lucram !
