sckump Pasionat
Data înscrierii: 05/Iun/2007 Mesaje: 139 Locație: Iasi
Trimis: Mie Noi 14, 2007 3:41 pm Titlul subiectului: Vand difuzor PROFESIONAL 12W700 Eighteen Sound 350W RMS |
Vand difuzor Profesional abia cumparat model Eighteen Sound 12W700, putere nominala (RMS) 350 Watt.
Pret: 400 lei
Pret pe net:
http://www.soundworks-pa-shop.de/product_info.php/products_id/1301
Detaliile tehnice mai jos sau pe pagina de net:
http://www.eighteensound.com/index.aspx?mainMenu=view_product&pid=218
DETALII TEHNICE:
Nominal Diameter 300 mm (12 in)
Rated Impedance 8 Ohm
Continuous Pink Noise (1) 450 W
Continuous Power (2) 350 W
Program Power (3) 700 W
Peak Power (4) 1500 W
Sensitivity (5) 98 dB
Frequency Range (6) 55 Ă· 4200 Hz
Power Compression @-10dB (7) (35 W) 0,8 dB
Power Compression @-3dB (175 W) 2,3 dB
Power Compression@Full Power (350 W) 3,1 dB
Max Recomm. Frequency 1700 Hz
Recomm. Enclosure Volume 40 Ă· 90 lt. (1,41 Ă· 3,18 cuft)
Minimum Impedance 7 Ohm at 25°C
Max Peak To Peak Excursion 34 mm (1,34 in)
Voice Coil Diameter 75 mm (2,95 in)
Voice Coil Winding Material aluminum
Polarity positive voltage on red terminal gives forward cone motion
THIELE SMALL PARAMETERS (
Fs 58 Hz
Re 5,7 Ohm
Sd 0,0531 sq.mt. (82,31 sq.in.)
Qms 3,93
Qes 0,37
Qts 0,36
Vas 55 lt. (1,94 cuft)
Mms 51 gr. (0,11 lb)
BL 17,7 Tm
Linear Mathematical Xmax (9) ± 6,5 mm (± 0,26 in)
Le (1kHz) 1,48 mH
Ref. Efficiency 1W@1m (half space) 97,2 dB
MOUNTING INFORMATIONS
Overall diameter 315 mm (12,4 in)
N. of mounting holes 8
Mounting holes diameter 7,15 mm (0,28 in)
Bolt circle diameter 296 - 300 mm (11,65 - 11,8 in)
Front mount baffle cutout ø 282 mm (11,1 in)
Rear mount baffle cutout ø 282 mm (11,1 in)
Total depth 147,5 mm (5,80 in)
Flange and gasket thickness 16,5 mm (0,65 in)
Net weight 8,2 kg (18,1 lb)
Shipping weight 9 kg (19,87 lb)
CardBoard Packaging dimensions 332 x 332 x 184 mm (13,07 x 13,07 x 7,24 in)
FREQUENCY RESPONSE CURVE OF 12W700 MADE ON 50 LIT. ENCLOSURE TUNED 60HZ INFREE FIELD (4PI) ENVIRONMENT.
Ultima modificare efectuată sckump la Lun Sep 15, 2008 11:43 am, modificat de 2 ori în total |
sckump Pasionat
Trimis: Dum Noi 18, 2007 7:19 pm Titlul subiectului: |
| Pret 440 RON (pe net e peste 650 RON) |
sckump Pasionat
Trimis: Dum Dec 02, 2007 12:26 pm Titlul subiectului: |
| Pret nou 420 RON. |
sckump Pasionat
Trimis: Vin Dec 21, 2007 1:21 am Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Vin Ian 04, 2008 4:07 pm Titlul subiectului: |
| Pret nou 400 ron. |
sckump Pasionat
Trimis: Dum Ian 06, 2008 9:30 pm Titlul subiectului: |
| Cineva interesat |
sckump Pasionat
Trimis: Mar Ian 08, 2008 1:46 am Titlul subiectului: |
| 400 RON. |
sckump Pasionat
Trimis: Sâm Ian 12, 2008 5:31 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Mie Ian 16, 2008 1:01 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Vin Ian 25, 2008 12:17 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Mie Mar 05, 2008 11:54 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Lun Mar 24, 2008 10:01 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Mar Apr 01, 2008 6:45 pm Titlul subiectului: |
| up |
sckump Pasionat
Trimis: Lun Mai 05, 2008 12:06 am Titlul subiectului: |
| up. |
sckump Pasionat
Trimis: Sâm Mai 17, 2008 11:11 pm Titlul subiectului: |
| up. |
