obie_triceps Priceput
Data înscrierii: 03/Iul/2006 Mesaje: 295 Locație: Braila/Bucuresti
Trimis: Mar Aug 13, 2013 10:23 am Titlul subiectului: Vand DLS CA22 |
Amplificator DLS CA22 - functioneaza perfect, a fost folosit pentru a amplifica o pereche de Tweetere DLS. Am cutia, factura si garantia din momentul achizitiei
Pret: 350 lei
Contact: 0740.559.712
Number of channels 2
Amplifier class AB
Mono bridge mode 4 ohm 200 W RMS
Output power in 2 ohm 2 x 100 W RMS
Output power in 4 ohm 2 x 60 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
High pass filter 15-500 Hz
Low pass filter 50 - 500 Hz
Low level output Yes
High level input with auto start Yes
Power consumption (idle) 0,5 A
Power consumption (max) 25 A
Rec. power cable Minimum 5AWG / 16 mm2
Fuses 1 x 25 A
Dimension (W x D x H) 250 x 212 x 67 mm / 9,84 x 8,35 x 2,63"
Weight 2,7 kg / 5,95 lb |
Trimis: Mie Aug 21, 2013 10:44 pm Titlul subiectului: |
| inca valabil |
Trimis: Mie Aug 28, 2013 9:25 pm Titlul subiectului: |
| sus |
Trimis: Mie Sep 25, 2013 6:46 pm Titlul subiectului: |
| Vandut!! |
