ohm
Data înscrierii: 10/Ian/2009 Mesaje: 4 Locație: Oradea
Trimis: Sâm Ian 10, 2009 2:41 pm Titlul subiectului: -Vand JBL LX-22 , NAD 3020 , AKAI DX-57 , AKAI GX-65 MkII... |
-boxe bookshelf JBL LX-22 pe 2 cai cu bassreflex.Boxele sunt in stare foarte buna,fara reparatii.Made in USA.Pret: 380 RON
-boxe bookshelf ENERGY Pro Series 1.5 pe 2 cai cu bassreflex.Boxele sunt impecabile,fara reparatii.Made in Canada.Pret: 380 RON
-Vand pick-up THORENS TD-180 cu doza STANTON 500 MkIII.Lipseste cureaua.Pret: 350 RON
-Vand egalizator TECHNICS SH-8055.Stare foarte buna.Made in Japan.Pret: 400 RON
- Real Time Spectrum Analyzer - Display
- 2 x 12 Band Spektrumsanalyzer
- Regelbereich: +/-12 dB
- MIC Eingang
- Pink Noise
- Tape Dubbing
- Gesamtklirrfaktor: 0,003%
- Frequenzgang: 10 Hz - 100 kHz, + 0 dB, - 1 dB
- GerÀuschspannungsabstand: 102 dB
- Ein-/ AusgÀnge : Line In , Line Out, Tape1 Rec, Tape1 Play, Tape2 Play, Tape2 Rec
- 12 Frequenzbereiche: 25 Hz, 40 Hz, 63 Hz, 100 Hz, 160 Hz, 250 Hz, 500 Hz, 1 kHz, 2 kHz, 4 kHz, 8 kHz, 16 kHz - Abmessungen: 430x270x110mm. B/T/H
-Amplificatoare:
-PIONEER A-656 Reference.Source direct,consum de la retea 650 W !!! 13,5 Kg.Stare f.f. buna.Made in Japan.Pret: 620 RON
-HARMAN KARDON HK-6500.Phono MM,MC,pre out,main in.Impecabil.Harman Kardon New York.Made in Japan.Pret: 450 RON
-legendarul NAD 3020.Finali Motorola 2N3055;MJ2955 ,pre out,main in,soft clipping.Stare foarte buna.Pret fix: 500 RON
-MARANTZ PM-450 vintage.Fader phono 1 - phono 2,microphone in,source - microphone mixing,treble - mid - bass control.Made in Japan.Pret: 320 RON
-Amplitunere:
-HARMAN KARDON HK-330i.Ultrawideband linear phase receiver.Impecabil.Harman Kardon New York.Made in Japan.Pret: 300 RON
-Cd playere:
-SONY CDP-X202ES din seria ESPRIT.Level file,dimmer,peak search,time fade,disc memo,all in & outputs are gold plated,fix & variable line out,optical digital out.Stare foarte buna.Made in Japan.Pret: 450 RON
-DENON DCD-1420.Real 20 bit Super Linear Converter,2 buc D/A converter Burr Brown PCM 54HP,computed multi function display system,iesire fixa,variabila,digitala coaxiala,digitala optica,telecomanda , 11Kg !!!.Made in Japan.Pret: 450 RON
-DENON DCD-620.Double super linear converter, 2 X PCM-56P Burr Brown D/A converter,KSS-150A optical unit.Stare foarte buna.Pret: 140 RON
-MARANTZ CD-63.Full ELNA , ELNA SILMIC II , ELNA CERAFINE capacitors,optical & coaxial digital output,all in & outputs are gold plated.Stare foarte buna.Pret: 250 RON
-SONY CDP-597.Peak search,time fade,auto space,a. cue,motorized line out,fix & variable out.Stare foarte buna.Pret: 150 RON
-PHILIPS CD-471.Bloc optic CDM-2 ! Convertor D/A TDA-1541.Stare foarte buna.Pret: 180 RON
-TECHNICS SL-PG440A.Peak search,time fade,auto cue,4 dac,MASH,bloc optic CDM 4/19 (laser cu deplasare in camp magnetic).Pret: 130 RON
-Casetofoane deck
-AKAI GX-65 MkII.Dual capstan,3 head Super GX,cassette stabilizer,bias fine,memory,remote senzor.Stare foarte buna.Made in Japan.Pret: 450 RON
-AKAI DX-57.Dual capstan,3 head,bias fine,counter memory,remote senzor.Stare foarte buna.Made in Japan.Pret: 300 RON
-TECHNICS RS-BX646.Auto tape calibration,3 head,memory,TPS,motorized cassette loading.Made in Japan.Pret: 280 RON
-NAD 6325.Play trimmer,CAR.Stare foarte buna.Pret: 150 RON
-SONY TC-FX66.Full logic control,laseramorphous head,fluorescent linear counter,line out for remote control.Made in Japan.Pret: 150 RON
-Vand tunere:
-SONY ST-S500ES din seria ESPRIT.Cal tone,DSD circuit,quartz lock digital synthesizer,preset scan.Stare foarte buna.Made in Japan.Pret: 240 RON
-ONKYO Integra T-4450.Antenna attenuator,IF band,HI-blend,preset scan.Impecabil.Made in Japan.Pret: 250 RON
-NAD 4020A ,tunerul amplificatorului legendar 3020 !Banda AM , FM ,de-emphasis 25uS , 50 uS ,75 uS.Stare foarte buna.Pret: 150 RON
-Poze reale: http://www.hififorall.weebly.com
Ultima modificare efectuată ohm la Dum Feb 21, 2010 12:23 pm, modificat de 74 ori în total |
ohm
Tibitzu Audiofil
Data înscrierii: 16/Feb/2009 Mesaje: 926
Trimis: Joi Apr 23, 2009 8:26 am Titlul subiectului: |
Salut amplificatorul pioneer PIONEER A-229 mai este disponibil? |
ohm
Trimis: Dum Feb 21, 2010 12:24 pm Titlul subiectului: |
thunder rock Pasionat
Data înscrierii: 14/Sep/2007 Mesaje: 83
Trimis: Vin Apr 16, 2010 4:11 pm Titlul subiectului: |
Pretul la cer ii poti da drumul la -AKAI GX-65 MkII? _________________ PIO DEH 6800 MP,DLS PS 4,SAL RFX2-130NEO,SUB. FOCAL BombA 20-A1 cabluri DIETZ.Viper 791XV |
