AlexBanu Priceput
Data înscrierii: 18/Iul/2008 Mesaje: 402 Locație: Bucuresti
Trimis: Lun Apr 18, 2011 1:48 pm Titlul subiectului: Vand mai multe componente car audio SQ |
Se vinde un amplificator Helix P400 in stare foarte buna.
Putere RMS/Putere Maxima la 4 Ohms - 4 x 110/190 Watts
Putere RMS/Putere Maxima la 2 Ohms - 4 x 175/300 Watts
Putere RMS/Putere Maxima la 4 Ohms - 2 x 350/595 Watts
Frecventa - 15 Hz - 20 kHz
Bassboost - 0 - 9 dB
Bassboost setting range for center frequencies - 40 - 120 Hz
Setting range highpass - 15 Hz - 4 kHz
Setting range lowpass - 15 Hz - 4 kHz
Distorsiune totala - < 0,006%
TIM - <0> 95 dB
Damping factor - > 600
IImpedanta de intrare - 10 kOhms
Senzitivitarte - 300 mV - 8,5 V
SIguranta - 3 x 25 A
Dimensiuni (H x W x D) mm - 35 x 432 x 240
Greutate Neta - 4,7 kg.
Class A Technology
IMS-Technologie (Integrated Managing Software)
16 MosFet Transistors
RMI (Realmixed Input)
NFI (Noisefree Input)
Intelligent active crossover
Mono/Bridged/Stereo switch
8 volt input
ADC (Anti Distortion Choke)
Intelligent power supply
Separate speaker protection circuit
CPS (Colour Protection System)
SMD (Surface Mounting Device)
Double-sided, extra strong and copper-plated pc-board
24-carat gold-plated solid connectors suitable for 25mm2 cable
Temperature-optimised heatsink
1% accurate components
massive connection terminals >50 mm2.
Se poate vedea si testa in Bucuresti.
Pret: 1600 lei
Se vinde un set de tweetere Micro Precision 5.28MKII
tweeter 28 mm
impendanta: 4 ohmi
putere: 80W
fs: 1400 Hz
frecventa: 2000-20.000
Pret: 800 lei
Midbass Brax 6.1 PP
Dimensiune difuzor 16.5 cm.
Putere RMS - 120 Watts
Putere Maxima - 170 Watts
Impedanta - 4 Ohms
DC rezistenta - 3,4 Ohms
Mechanical Q Qms - 8,03
Electrical Q Qes - 0,65
Total Q Qts - 0,59
Xmax - 4,00 mm (+/-)
Moving mass md - 21,3 g
Sensitivitate - 88,9 dB (2,83V/1m)
Rezistenta Mecanica - 0,82 kg/s
Compliance - 0,49 mm/N
Force factor - 6,18 Tm
Equivalent volume Vas - 12,59 l
Frecventa in rezonanta - 49 Hz
Diametru de instalare/adancimea - 143 x 64 mm.
PRET - 1200 lei
Se vinde o bucata subwoofer SQ - Mac Audio Aliante 10" Black Limited
Putere nominala 400W RMS
Putere maxima 1000W
Impedanta 4 ohmi
Raspuns in frecventa 20-250Hz
Sensibilitate 878dB
Sasiu din aliaj de otel si aluminiu
Membrana plata din fibra de aluminiu pe structura fagure
Bobina de mare putere de 125mm cu racire tip fero-fluid
Pret 700 lei
Preturile nu sunt discutabile!
Toate produsele se pot vedea si testa in Bucuresti.
0722942008/0765446422 _________________ Alpine F#1 Status/MicroP.7.28MKIII/Z170MKIII/Brax Matrix X4/Helix A1 Competition/Aliante 10" LTD |
AlexBanu Priceput
Trimis: Mar Apr 19, 2011 11:05 am Titlul subiectului: |
se mai adauga la vanzare inca un set de medii in stare f buna Micro Precision 5.8 MK II
difuzor medie 10 cm
impendanta: 6 Ohm / 91 dB/ W / M.
putere: 30W
frecventa: 150-16.000 Hz
PRET - 450 lei _________________ Alpine F#1 Status/MicroP.7.28MKIII/Z170MKIII/Brax Matrix X4/Helix A1 Competition/Aliante 10" LTD |
