raresdec
Data înscrierii: 09/Apr/2010 Mesaje: 12
Trimis: Joi Mai 06, 2010 8:02 pm Titlul subiectului: Vand monitoare de studio INFRASONIC BLOW 5 |
Vand monitoare de studio INFRASONIC BLOW 5,active,biamplificate 40w+50w,se aud impecabil,le am de 2 luni,nu au in total 20 de ore ascultate.
Pret:1000 ron negociabil.
Specificatii producator:
System / Enclosure
* Two-way, bi-amplified reference monitor (bass-reflex type)
* Free field frequency Response: 58Hz ~ 20kHz (+/- 1.5 dB)
* Free field cutoff response 50Hz ~ 22kHz (+/- 3.0dB)
* Enclosure Resonant Frequency (vent tuning): 62Hz
* Measured Maximum Continuous: 105dB SPL / 1m
* Harmonic distortion at 90 dB SPL @ 1 m on axis: 0.5% under
* Low frequency driver:
- Diaphragm Type: Polymer coated paper fiber cone type
- Diameter: 5-1/4" (133 mm)
- Voice Coil: 1.0" (25 mm)
- Magnet Type: Ferrite magnet with magnetically shielded
- Impedance: 8 ohms
* High Frequency Driver
- Diaphragm Type: Natural Silk Dome with Waveguide.
- Diameter: 0.75" (19mm) diaphragm
- Impedance: 8 ohms
* Low Frequency Vent Type : Front ported, Slotted aperture
* Internal cabinet volume: 7.2 liters
* Enclosure Construction: 15mm (5/8 ) Vinyl-laminated M.D.F
* Dimensions : (190 mmW x 300 mmH x 266 mmD)
* Weight : 6.5 kg
Amplifier / Crossover
* Power amplifier topology:
- Class A-B Full discrete power device amplifier with Servo-loop
- DC, Over-load and Over-current protection
- Supply monitoring protection with Mute control
* Output power rating:
- 50watts (<0.1% THD into 8 ohm)
- 40watts (<0.1% THD into 8 ohm)
* Total Harmonic distortion + Noise: <0> 106dB
* Slew rate : >15V/us
* Input sensitivity control range (@output power 60W, trim):
+22dBu at control min
-9dBu at control max
* Connector: XLR input, 1/4" TRS Balanced input (impedance 20kOhm)
* Crossover: 3.0 kHz, 30dB/otc 5th order active filter
* High frequency tilt control : -2dB / Flat / +2dB (@ 10kHz)
* Room control : Flat / -2dB / -4dB (@ 100Hz)
* Base cut-off frequency control : Flat / 80Hz(THX) / 100Hz (-12dB/octave)
* Acoustic System Compensation rage : 30Hz ~ 200Hz, +/-6dB Max
* Indicator: power/protection (front, white LED)
* AC Power Input :
- Max rated power : 115 watts
- 100 ~ 120VAC, 200 ~ 240VAC, 50~60Hz via IEC power INLET |
