dark_m4n01
Data înscrierii: 31/Ian/2013 Mesaje: 7
Trimis: Joi Ian 31, 2013 8:15 pm Titlul subiectului: Vand Power Acoustik BAMF-5500/1D |
Vand Power Acoustik BAMF-5500/1D:
•5500W Max Monoblock Class D Amplifier Car Amplifier
•RMS Power Rating:
◦4 ohms: 1700 watts x 1 chan.
◦2 ohms: 2300 watts x 1 chan.
◦1 ohm: 3200 watts x 1 chan.
•Max power output: 5500 watts x 1 chan.
•Fully regulated PWM power supply
•Wired remote bass level control included
•System distress indicator
•Four way protection circuit
•Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
•Hi-Speed digital circuitry
•Full selectable crossover (HI,Full,Low
•1-Ohm Stable
•Full selectable crossover (HI,Full,Low)
•Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
•Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
•Platinum-plated RCA level inputs
•Platinum-plated screw terminals
•Variable low-pass filter (40-200 Hz, 12 dB/octave)
•Variable subsonic filter (20-50 Hz)
•Variable subwoofer EQ @ 45 Hz
•Frequency response: 20-200 Hz
•Signal to Noise Ratio: 100 dB
•Dimensions: 16-7/8"L x 8-1/4"W x 2-1/8"H
Pret 700 RON nediscutabil, predare in Bucuresti.
Yahoo ID: dark_m4n |
darkofeel Priceput
Data înscrierii: 09/Iul/2009 Mesaje: 270 Locație: Bucuresti/Berceni
Trimis: Sâm Feb 02, 2013 2:10 am Titlul subiectului: |
Cu 700 RON il aduc tipla din SUA cu toate taxele incluse... Mai gandeste-te asupra pretului. _________________ I don't need to "get a life." I'm a gamer. I have lots of lives! |
mgm2000ro Priceput
Trimis: Sâm Feb 02, 2013 1:22 pm Titlul subiectului: |
Pe vanzare nu se face asa ceva, omul il vinde cu cit vrea, e dreptul lui sa ceara cit vrea! _________________
darkofeel Priceput
Trimis: Sâm Feb 02, 2013 2:20 pm Titlul subiectului: |
Cu respect MGM, dar sunt total in potriva bisnitei, mai ales ca pe forumuri ar trebui sa fie acel pret mai mic decat ori-unde...
Suntem intre noi si intre noi trebuie sa avem preturi corecte. _________________ I don't need to "get a life." I'm a gamer. I have lots of lives! |
georgebaciu Pasionat
Data înscrierii: 21/Noi/2012 Mesaje: 61 Locație: ploiesti
Trimis: Sâm Feb 02, 2013 3:13 pm Titlul subiectului: |
mi se pare acceptabil la pret din Sua il iei cu 700 fara taxe care mai sunt undeva la 80-90 de dolari _________________ GZRW 30SPL |
stoica22 Priceput
Trimis: Sâm Feb 02, 2013 3:59 pm Titlul subiectului: |
wow un amplif de 3000w la doar 7 mil? |
Trimis: Sâm Feb 02, 2013 4:11 pm Titlul subiectului: |
chiar 3200,  _________________ GZRW 30SPL |
stoica22 Priceput
Trimis: Sâm Feb 02, 2013 4:28 pm Titlul subiectului: |
lasa ma ca n-am eu curent nici de 3000w pe masina )
Trimiti si in tara ampliful? in ce stare e? ceva poze? |
dark_m4n01
Trimis: Sâm Feb 02, 2013 4:43 pm Titlul subiectului: |
Pretul este 700RON, cine il vrea tipla sa vorbeasca cu darkomuci sa-l aduca din sua. |
Trimis: Sâm Feb 02, 2013 4:50 pm Titlul subiectului: |
are si siguranta de 200A , pare destul de bun, cred ca mere alimentat la 220V:)) _________________ GZRW 30SPL |
mgm2000ro Priceput
Trimis: Sâm Feb 02, 2013 5:02 pm Titlul subiectului: |
Poate 1200w/1 din experienta mea, asta nu inseamna ca nu poate si 5500w!
Lasati vanzarea sa decurga normal ! _________________
mgm2000ro Priceput
Trimis: Sâm Feb 02, 2013 5:07 pm Titlul subiectului: |
uni spun ca poate si 2kw dar la 14.2 V  _________________
alexandru.antrax Priceput
Trimis: Sâm Feb 02, 2013 6:31 pm Titlul subiectului: |
amplificatorul "poate" , din calcule, aprox 2300W la 1 ohm , asta la o tensiune de 14,4V, asta daca poti sa mentii tensiunea aia |
cTn_Jenica
Data înscrierii: 02/Feb/2013 Mesaje: 15 Locație: Mehedinti
Trimis: Sâm Feb 02, 2013 10:25 pm Titlul subiectului: |
salut vreau sa iau amplifu.Da il poti trimite prin curier ca nu pot ajunge in bucuresti. |
dark_m4n01
Trimis: Dum Feb 03, 2013 10:57 pm Titlul subiectului: |
Ai ID-ul meu de Yahoo in primul post, da-mi add si ti-l trimit. Singura conditie este sa-mi platesti in avans curierul ( in cazul in care nu ridici coletul din diverse motive sa nu pierd nimic ). |
