VAND/Schimb Amplificator + subwoofer
Ciochy
Data înscrierii: 17/Noi/2008
MesajTrimis: Mie Iul 29, 2009 8:21 pm    Titlul subiectului: VAND/Schimb Amplificator + subwoofer Răspunde cu citat (quote)
JBL Gto 1204BR
subwoofer in incinta Bass-Reflex
difuzor GTO 1204, diametru 300 mm
putere: 300W RMS (1200W max)
SPL (2.83V/1m): 93dB
raspuns in frecventa 35 - 300 Hz
impedanta 4 ohmi
dimensiuni (H x W x D) 520 x 414 x 370 mm
Pret: 350 ron
Statie Pioneer GM-5100T
Key features GM-5100T
Bridgeable 2-channel capability 2 x 250 W or 1 x 760 W (Max. Power)
Continuous output power: 2 x 125 W or 1 x 380 W (4 Ω) 2 x 190 W (2 Ω)
2 x 175 W or 1 x 520 W (4 Ω) DIN Power (DIN 45324, +B = 14.4 V)
Load impedance capability (2 — 8 Ω)
LPF: 80 Hz, -12 dB/Oct
High Voltage Input capability (200 mV — 6.5 V)
Features GM-5100T
Type Bridgeable Power Amplifier
PWM regulated MOSFET power supply Yes
Channels 2
Load impedance capability 2 - 8 Ohm
Bass Boost 50 Hz
0/6/12 dB
RCA input terminals Yes
Speaker Terminals Screw-type
Power / ground terminals Large screw-type
LPF 80 Hz
High voltage input capability 200 mV - 6.5 V
High performance balanced isolator circuit Yes
Speaker line input Yes
Specifications GM-5100T
Maximum Output Power 2 x 250 Watt or 1 x 760 Watt (4 ohms)
DIN power output (W)
(DIN45324, +B = 14.4V) 2 x 175 W or 1 x 520 W (4 ohms)
Continuous power output (RMS) 2 x 125 Watt or 1 x 380 (14.4V (20-20kHz/4ohms))
2 x 190 (14.4V (20-20kHz/2ohms))
Frequency response 10 Hz - 50.000 Hz
Distortion 0,015 %
S/N ratio > 95 dB
High Voltage Input Capability 200 mV - 6.5 V
Max. current consumption (A/4ohms) 30 A
Chassis size (W x H x D) 300 x 60 x 327 mm
Unit weight 4.7 kg
Pret: 350 ron
Schimb cu boxe sistem + statie
Ciochy
MesajTrimis: Mie Aug 05, 2009 10:12 am    Titlul subiectului: Răspunde cu citat (quote)
__/UP\__
Ciochy
MesajTrimis: Joi Aug 06, 2009 10:25 am    Titlul subiectului: Răspunde cu citat (quote)
UP
Sharkky
Data înscrierii: 11/Mar/2007
MesajTrimis: Joi Aug 06, 2009 3:02 pm    Titlul subiectului: Răspunde cu citat (quote)
Citeste regulamentul ...
http://www.be-loud.ro/forum/regulament-bursa-cititi-inainte-t1919.html
Ciochy
MesajTrimis: Vin Aug 14, 2009 10:20 pm    Titlul subiectului: Răspunde cu citat (quote)
up
raven2k1
Data înscrierii: 27/Iun/2007
MesajTrimis: Mar Aug 18, 2009 6:18 pm    Titlul subiectului: Răspunde cu citat (quote)
Lasi statia la 300?
adi2mad
Data înscrierii: 28/Oct/2008
Locație: Radauti
MesajTrimis: Mie Aug 19, 2009 3:07 pm    Titlul subiectului: Răspunde cu citat (quote)
Mai e valabil anuntul? Daca da imi poti spune de unde esti? Si care e pretul final la tot sistemul?
22...going on..HONDA
Ciochy
MesajTrimis: Mie Aug 19, 2009 5:04 pm    Titlul subiectului: Răspunde cu citat (quote)
sunt din Alba pret final 650 ron
Ciochy
MesajTrimis: Sâm Aug 29, 2009 12:33 am    Titlul subiectului: Răspunde cu citat (quote)
up
mishuxxi
Data înscrierii: 06/Mar/2008
Locație: mioveni
MesajTrimis: Lun Oct 12, 2009 11:55 pm    Titlul subiectului: salut! Răspunde cu citat (quote)
m-ar interesa si pe mine amplificatorul, mai e valabil?
