VAND SCULE CAR-AUDIO (curatenia de primavara)
Tibitzu
Data înscrierii: 16/Feb/2009
MesajTrimis: Dum Mar 01, 2009 5:48 pm    Titlul subiectului: VAND SCULE CAR-AUDIO (curatenia de primavara) Răspunde cu citat (quote)
Amplificator ORION HCCA D5000
5000W Class D Competition Mono Amplifier
RMS @ 4 Ohm: 1 x 1000 (13,8v)
RMS @ 2 Ohm: 1 x 1600 (13,8v)
RMS @ 1 Ohm: 1 x 2500 (13,8v)
RMS @ 4 Ohm: 1 x 1100 (14,4v)
RMS @ 2 Ohm: 1 x 1750 (14,4v)
RMS @ 1 Ohm: 1 x 2700+ (14,4v-16.00v)
Valorile sunt date la 0.1% THD
Variable low-pass 30Hz to 250Hz
variable high-pass with INTELLi Q 20Hz to 150Hz
10dB of boost with INTELLi Q
Remote gain capable
Selectable AUX out
Dimentions: 22.8" x 10.2" x 2.4"
Power Rating: 1000 Watts RMS x 1 at 4 ohms
Signal to Noise Ratio: -59dBA (reference 1 watt into 4 ohms)
Additional Power Output: 2500 Watts RMS at 1 ohm
Massive loosely-regulated MOSFET power supply
IntelliQ Bass Optimization Circuit and Remote Gain Control
Heavy Gauge Direct-wire High Current Power and Speaker Terminals
18dB/octave Low-pass Filter
Telecomanda (remote) pe fir
Dimension: 22.8” x 10.2” x 2.4” (58cm x 26cm x 6cm)
Se livreaza in ambalajul original cu toate accesoriile de la producator
Se prezinta impecabil atat functional cat si estetic (fara urma de zgarietura )nota:10/10
Folosit aproximativ 5 luni
Poze se pot vedea aici :
http://ampguts.realmofexcursion.com/Orion_HCCA-D5000/
PRET: 2200 RON (transport inclus)
Amplificatoare DB TWO Dark Blue
(2 BUCATI)
amplificator auto 2 canale
putere:
stereo, 4 ohmi: 2 x 80W RMS
stereo, 2 ohmi: 2 x 120W RMS
punte, 4 ohmi: 1 x 200W RMS
raspuns in frecventa: 10 Hz - 30 KHz
BassBoost variabil 0-18 dB
filtre active integrate:
filtru HPF (trece-sus) variabil 15 Hz - 4 KHz
filtru LPF (trece-jos) variabil 40 Hz - 4 KHz
filtru bandpass variabil 15 Hz - 4 KHz
THD <0> 93 dB (raport semnal/zgomot)
semnal intrare 200mV - 8V
sigurante: 1 x 30A
dimensiuni: 53 x 283 x 277
Amplificatoarele sunt impecabile din toate punctele de vedere "sunt sigilate" cei care au mai cumparat de la mine stiu cum arata...
Garantie 2 ani!!!
AM 2 BUCATI...
PRET: 400 RON
LCD ZENEC ZE-MU703 7"
Specificatii:
high resolution TFT-LCD A-grade active matrix displays
generous viewing angles: left/right > 60° / above > 30° / below > 60°
onscreen menu operation directly on unit
automatic NTSC/PAL switching
2 A/V inputs (RCA and 3.5 mm jack socket on the front panel)
1 headphone output (3.5 mm jack socket on the front panel)
A/V-Interface with quick release for power and A/V input
bezel for headrest installation included in the set
SE PREZINTA IMPECABIL DIN TOATE PUNCTELE DE VEDERE ZGARIETURI 0 FOLOSIT APROXIMATIV 2 ORE ,ARE O IMAGINE IMPECABILA SE LIVREAZA IN AMBALAJ ORIGINAL CU TOATE ACCESORIILE DE LA PRODUCATOR. (motivul vanzarii nu am loc in masina pentru montaj )
Detalii si poze : http://www.zenec.com/index.php?id=36&L=1
PRET: 300 RON
DVD AUTO/HOME PORTABIL sata-HDD
Movies/Music/Photos; do you want to store them all in 1 place and play back at once? Do it with GP-MED35. This device is made for almost all media playbacks with a simple connection to TV or hi-fi system. Made for 3.5" SATA, and it allows users store as much as possible (HDD installation required). Furthermore, internal 8cm cooling fan sustain HDD under long-hour movie playback.
This multimedia player lets you carry your data anywhere you go! Compatible with 3.5" HDD, It is no longer just an external storage. It is also a portable music/movie theater for you!! All you have to do is just to connect AV inputs on any television, its user-friendly interface can play MPEG-4, DVD, VCD and Digital camera photo on TV or Computer monitor with a touch the remote control. It also supports Hi-speed USB2.0 for data transfer up to 480 Mbps
Features:
HD component output for 720p/1080i JPEG display
Scaler for video up-conversion to 720p/1080i
Remote controller
8CM internal cooling fan
Movie Preview function for all support media formats
8 Acoustic sound effect for MP3 EQ adjustment
Direct connection to TV & HI-FI speakers
Moive playback:
PREVIEW function
Repeat 1/all
FW/BW: 2X/4X8X/16X
Specifications:
HDD Support 3.5 inch SATA
Firmware Upgrade Yes
Display Format PAL/NTSC remote assisted switch
Media Output YPbPr
VGA
A/V
Movie File Support MPEG1: AVI / MPEG / DAT
MPEG2: VOB
MPEG4: AVI/Divx5.0/Xvid/GMC/QPEL
Motion JPG
Audio File Support MP3/WAV/AAC
Photo File Support BMP/TIFF/PNG/GIF/JPG
Material Aluminum Cover and Metal Interior
System Support Windows 98SE/ ME/ 2000 /XPVista
Macintosh OS 8.6 or higher
Linux Kernel 2.4.1.0 or above
Size(L x W x H) 192 x 125 x 45 mm
MADE IN SUA
Se poate folosii impreuna cu playerul masinii...
Are foarte multe accesorii care nu se vad in poze.
SE PREZINTA IMPECABIL DIN TOATE PUNCTELE DE VEDERE ZGARIETURI 0 FOLOSIT APROXIMATIV 10 MINUTE ,ARE O IMAGINE IMPECABILA SI UN SUNET LA FEL DE IMPECABIL (iesire stereo,egalizator) SE LIVREAZA IN AMBALAJ ORIGINAL CU TOATE ACCESORIILE DE LA PRODUCATOR.(motivul vanzarii nu am loc in masina pentru montaj )
PRET: 600 RON
PRETURILE SUNT FIXE SI NU ACCEPT NEGOCIERI SAU SCHIMBURI.PRODUSELE SE LIVREAZA PERSONAL IN ZONA (MILITARI-BUCURESTI vineri-sambata-duminica) SE POT OFER ORICE FEL DE PROBA/VERIFICARE/ASCULTARE LA MINE PE MASINA.
SCHIMBURI SE ACCEPTA LA DVD SAU LCD SI SE SCHIMBA CU GPS + DIFERENTA.
POZE SI MENTORAT GRATIS Very Happy
Detalii:
YM - yo_tibitzu
TEL - 0747535280
sau pe privat.
Ultima modificare efectuată Tibitzu la Lun Mar 09, 2009 8:03 pm, modificat de 14 ori în total
baubau
Data înscrierii: 12/Noi/2006
Locație: timisoara
MesajTrimis: Lun Mar 02, 2009 1:27 pm    Titlul subiectului: Răspunde cu citat (quote)
up pentru un amp grozav , care a facut un scor grozav cu un type r de 12!!!
Tibitzu
MesajTrimis: Lun Mar 02, 2009 4:34 pm    Titlul subiectului: Răspunde cu citat (quote)
Multumesc mult!!! da Este un amplificator superb ...
PS:Am pus si alte scule multimedia Very Happy nu am loc sa le montez in masina si este pacat sa se puna praful pe ele.
MesajTrimis: Lun Mar 02, 2009 6:34 pm    Titlul subiectului: Răspunde cu citat (quote)
Shocked mai spart ...
asa se intampla daca ai construit carutza in casa ... nu ai cum so scoti ...
bafta la vanzare
YM: shokaliptiku
Tibitzu
MesajTrimis: Lun Mar 02, 2009 7:00 pm    Titlul subiectului: Răspunde cu citat (quote)
Da se poate monta dar nu am timp de fibra si alte chestii...asta este sunt nevoit sa fac rost de bani ca am belele Laughing
Ultima modificare efectuată Tibitzu la Lun Mar 02, 2009 7:19 pm, modificat de 2 ori în total
MesajTrimis: Lun Mar 02, 2009 7:04 pm    Titlul subiectului: Răspunde cu citat (quote)
Laughing Laughing Laughing
da da da si marmota invelea ciocolata .. cu multa grija , desigur !
imi pare tare rau ca dai ampul ... ai avut scoruri bune "din cauza lui" ...
hai sa fie vanzarea intr-un ceas vacheron constantin cu cuc si pupaza
YM: shokaliptiku
Tibitzu
MesajTrimis: Mar Mar 03, 2009 7:47 pm    Titlul subiectului: Răspunde cu citat (quote)
da are scoruri foarte bune este un amplificator extraordinar
PENTRU DVD SAU LCD ASTEPT SI SCHIMBURI CU CAR AUDIO SAU GPS
Tibitzu
MesajTrimis: Vin Mar 06, 2009 4:06 pm    Titlul subiectului: Răspunde cu citat (quote)
Up pentru jucariile care isi asteapta proprietarii...
PS.Am mai adaugat 2 amplificatoare HELIX
zeusrazvy
Data înscrierii: 29/Mai/2007
Locație: Cluj
MesajTrimis: Vin Mar 06, 2009 6:17 pm    Titlul subiectului: Răspunde cu citat (quote)
e 559 cu tot cu transport un db two dark blue tu il dai la 450 +transport..???
Tibitzu
MesajTrimis: Vin Mar 06, 2009 7:29 pm    Titlul subiectului: Răspunde cu citat (quote)
Comentarii despre preturi poti face la tine pe topic ... daca vreau il pot da si cu 800 ron ...
Uite pentru tine il las la 400 ca sa fi multumit si sa nu mai comentezi ...
VA ROG SA VA ABTINETI DE LA COMENTARII
eX "CA POT LUA AMPLIFICATOR 2X80 CU 250 RON"
bezz
Data înscrierii: 05/Iun/2007
Locație: on a vibe
MesajTrimis: Vin Mar 06, 2009 8:44 pm    Titlul subiectului: Răspunde cu citat (quote)
ca s-o lamurim dinainte, la schimburi, te intereseaza schimb cu subwoofer gibiel de 300W sau schimb cu amplificator blaupunkt de 250 ron (la domo)?
LE legat de orion, la banii aia ... imi iau doua juice Laughing Laughing Laughing
Wink bafta la vanzare
Ultima modificare efectuată bezz la Vin Mar 06, 2009 9:10 pm, modificat de 2 ori în total
Tibitzu
MesajTrimis: Vin Mar 06, 2009 8:50 pm    Titlul subiectului: Răspunde cu citat (quote)
Da exact asa s-a pus problema ca vezi "cam scump amplificatorul tinanad cont ca este sh si oricum cu 250 ron imi iau amplificator 2 x 80 "
Ca sa nu mai comenteze nimeni amplificatoarele HELIX sunt SIGILATE si nu se compara cu mac,gibiel (ms bezz) sau blaupunkt de la domo....
Ma mir cum de nu mi-ati comentat si pretul la ORION ..."ca la banii aia imi iau JBL nou"...
alexD
Data înscrierii: 09/Apr/2008
MesajTrimis: Sâm Mar 07, 2009 3:36 am    Titlul subiectului: Răspunde cu citat (quote)
fara suparare la 250 iti iei un 2x25 w clasa ASmile genessis , care e mai slab decat cei 2x80w de la MAC sau geilbiel.
bafta la vanzare
zeusrazvy
Locație: Cluj
MesajTrimis: Sâm Mar 07, 2009 4:18 am    Titlul subiectului: Răspunde cu citat (quote)
ai inteles gresit nu am precizat nici unde ca pot cumpara cu 250 un blaupunkt sau mai stiu eu ce pentru ca nu prefer nici eu asa ceva.... pur si simplu intrebam.. pentru ca nu vedeam avantaju intre a cumpara de pe site sau de la tine.. imi cer scuze daca ai inteles ceva gresit asa da mai merge daca le dai la 400 Very Happy si acum vad ca oferi si garantie.. deci my mistake
Tibitzu
MesajTrimis: Sâm Mar 07, 2009 10:48 am    Titlul subiectului: Răspunde cu citat (quote)
Garantie am oferit de la inceput... Rolling Eyes ...
