cipry01
Data înscrierii: 11/Ian/2014 Mesaje: 8 Locație: Bucuresti
Trimis: Sâm Ian 11, 2014 12:15 pm Titlul subiectului: Vand subwoofer JBL + amplificator DLS CA 22 |
Subwoofer auto JBL in stare foarte buna. Difuzor 12" membrana cauciuc.
Date technice:
JBL GT4 High Performance Subwoofer
Typ: Bass Reflex
RMS Belastbarkeit: 250 W - Putere nominala (Sinus)
Max. Belastbarkeit: 1000 W - Putere maxima
Wirkungsgrad: 94 dB
Frequenzbereich: 26-300 Hz - Gama de frecventa
Nennimpedanz: 4 Ohm - Impedanta
MaĂe: 455 x 440 x 360 mm - Dimensiuni
Amplificator DLS CA22
Number of channels 2
Amplifier class AB
Mono bridge mode 4 ohm 200 W RMS
Output power in 2 ohm 2 x 100 W RMS
Output power in 4 ohm 2 x 60 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
High pass filter 15-500 Hz
Low pass filter 50 - 500 Hz
Low level output Yes
High level input with auto start Yes
Power consumption (idle) 0,5 A
Power consumption (max) 25 A
Rec. power cable Minimum 5AWG / 16 mm2
Fuses 1 x 25 A
Dimension (W x D x H) 250 x 212 x 67 mm / 9,84 x 8,35 x 2,63"
Weight 2,7 kg / 5,95 lb |
cipry01
Trimis: Sâm Ian 11, 2014 12:20 pm Titlul subiectului: |
| pret 500 ron |
grz666
Data înscrierii: 15/Ian/2014 Mesaje: 1 Locație: Bucuresti
Trimis: Mie Ian 15, 2014 3:09 am Titlul subiectului: |
| subwooferul separat se vinde? daca da ce pret. multumesc |
cipry01
Trimis: Mie Ian 15, 2014 10:06 am Titlul subiectului: |
Salut!
Da il dau si separat, 300 de lei daca te intereseaza.
Ms! |
