Shokaliptiku Audiofil
Trimis: Mie Mai 26, 2010 12:14 pm Titlul subiectului: VAND subwoofer+amplificator |
Cu durere ... peste tot
tin sa anunt ca sculele care m-au ajutat sa zambesc la concursuri
si sa ma faca mandru .. la premieri
se dau spre vanzare ...
astfel :
subwoofer SOUNDSTREAM SPLX 124
* Sensitivity: 98.2 dB
* RMS Power Range : 1000 Watts
* Peak Power Handling: 2000 Watts
* Impedance: 4 Ohm
* Low Frequency response: 35 Hz
* High Frequency Response: 1400 Hz
* Diameter: 12 Inch
Features
* Max: 2000W Burst
* Max power handeling: 1000W
* Magnet Wgt. (oz): 192
* Frequency response: 25-1.4kHz
* Mounting hole size: 11.25"
* Woofer depth: 7.25"
* Recommended enclosure: 1.5
* Recommended enclosure type: vented
* Cast aluminium basket
* Large -roll foam surround
* Dual stacked magnet structure
* Aluminum voice coil former
* Extended back-plate with Aero-Vent
* Stitched tinsel leads
* Spring loaded push terminals
* Rubber gasket
* Rubber magnet cover
si
amplificator SPL DYNAMICS S6002
RMS Power 4 Ohm
2 x 300W
RMS Power 2 Ohm
2 x 500W
RMS Power 4 Ohm mono
1 x 1000W
THD (A-weight)
< 0,08%
Input sensitivity
200mV - 4.5 V
Low Pass (12/24 dB/oct)
40 - 4000 Hz
High Pass (12/24 dB/oct)
15 - 4000 Hz
High Pass & Low Pass filters can be used at the same time
so them can be used as a bandpass filters. High Pass filter
can also be used as a Subsonic filter for subwoofer.
PRET sub: 1100 RON
PRET amp : 1200 RON
fara prea multe discutii .. si mult prea PUTIN negociabil |
Mycutzu
Data înscrierii: 13/Mai/2010 Mesaje: 42 Locație: Bucuresti
Trimis: Mie Mai 26, 2010 2:21 pm Titlul subiectului: |
te-ar interesa o combinatie la amplificator cu o statie T1 Audio LS500.2 +subwoofer magnat NeoForce 2100 + o dif d bani? |
Trimis: Mie Mai 26, 2010 4:24 pm Titlul subiectului: |
nu
multumesc |
Trimis: Joi Iun 03, 2010 8:02 pm Titlul subiectului: |
up |
Seal Priceput
Data înscrierii: 03/Dec/2008 Mesaje: 570
Trimis: Vin Iun 04, 2010 10:57 am Titlul subiectului: |
super scule cu super scoruri scoase  |
nitrouxboy Pasionat
Data înscrierii: 21/Aug/2008 Mesaje: 57 Locație: Moldova Noua
Trimis: Mar Iun 15, 2010 3:49 am Titlul subiectului: |
Poze reale cu amplificatorul se poate ? _________________ nimic de afisat! |
