Spliffu Pasionat
Data înscrierii: 26/Noi/2010 Mesaje: 136 Locație: Bwukale
Trimis: Joi Ian 02, 2014 10:59 pm Titlul subiectului: [VĂąnd] Subwoofer Sundown Audio SA-12 + incinta |
Specificatii:
600-watts RMS Power Handling
19.0mm X-Max by 70% BL method one-way (38.0mm peak to peak)
Thick black anodized aluminum voice coil formers for maximum strength and heat dissipation
4-layer copper high temperature voice coil windings with 45mm winding length
Double layer permanently bonded high strength Nomex spider pack for maximum longevity and durability
Thick flat tinsel lead wires tied down to the spider to prevent lead noise and breakage
Custom tooled triple joint support ring
Custom tooled frame spacer / ventilation ring
High efficiency air-flow management integrated into the motor for maximum voice coil cooling
Dual Aluminum Faraday rings for reduced inductance and inductive distortion (pole cap and magnet ID)
Two-Year Warranty against defects in materials and workmanship (full warranty text on our web-site)
Achizitionat (nou) prin august-septembrie 2012. Functioneaza fara probleme.
Pretul este 1000 lei si include difuzorul, incinta din imagine(55L 35Hz) + stikerul Sundown Audio. _________________ I stay alert and shoot first. |
Spliffu Pasionat
Trimis: Lun Ian 13, 2014 7:14 pm Titlul subiectului: |
Valabil. _________________ I stay alert and shoot first. |
Spliffu Pasionat
Trimis: Lun Ian 27, 2014 7:21 pm Titlul subiectului: |
Spliffu Pasionat
Trimis: Dum Mar 02, 2014 8:30 pm Titlul subiectului: |
Eventual schimb tot cu ceva de 12" plus diferenta. _________________ I stay alert and shoot first. |
Spliffu Pasionat
Trimis: Sâm Iun 28, 2014 6:06 pm Titlul subiectului: |
La pachetul actual se mai adauga inca 3 incinte, cele de aici : www.be-loud.ro/forum/vand-3-incinte-t16403.html plus inca una bandpass. Revin cu detalii despre incinta bandpass. In momentul de fata oferta suna cam asa, un sa12 + 4 incinte la pretul de 1000 lei. Am si eu o oferta la randul meu si daca se poate materializa ok, da nu raman la sundown. Nu raspund la intrebari gen ultimul pret sau ofertelor sub pretul afisat. _________________ I stay alert and shoot first. |
Spliffu Pasionat
Trimis: Sâm Iun 28, 2014 9:41 pm Titlul subiectului: |
Dimensiuni incinta bandpass:
68cmX45cmX40cm
Partea inchisa are 35.6L, cea bas reflex 56.3L utili final cu porturi luate in calcul. Acordaj 38.7 hz, porturile au 12.5cm diamentru cu 16cm lungime. _________________ I stay alert and shoot first. |
