Pioneer sau JL
Keno
Data înscrierii: 18/Sep/2010
MesajTrimis: Lun Aug 20, 2012 1:28 pm    Titlul subiectului: Pioneer sau JL Răspunde cu citat (quote)
Am de ales dintre doua woofere pentru o incinta din fibra de sticla.
Vreau sa o fac reflex si nu stiu care woofer ar fi mai potrivit dintre urmatoarele doua (am nevoie de niste opinii sau daca aveti alte idei de woofere pana in 250 de lei):
JL - 12W1v2-4
Free Air Resonance (Fs) 23.68 Hz
Electrical “Q” (Qes) 0.443
Mechanical “Q” (Qms) 6.465
Total Speaker “Q” (Qts) 0.414
Equivalent Compliance (Vas) 3.739 cu ft / 105.81 L
One-Way Linear Excursion (Xmax)* 0.375 in / 10 mm
Reference Efficiency (no) 0.304%
Efficiency (1 W / 1 m)** 86.81 dB SPL
Effective Piston Area (Sd) 81.392 sq in / 0.0525 sq m
DC Resistance (Re) 4.101 Ω
sau
Pioneer TS-W304R
Maximum input power 1.300 W
Nominal input power 300 W
Impedance 4Ω
Frequency response 20 - 220 Hz
Sensitivity (1W/1m) 95 dB
Woofer size 30 cm
Woofer material IMPP cone
Voice Coil bobbin type Extended and Vented pole yoke
Cut-out Hole 283,0 mm
Mounting Depth 134,5 mm
__________________________________________________
Thiele/Small Parameters
Nom. Dia.(In) 12
Qts 0,70
Qms 13,30
Qes 0,740
Fs [Hz] 28,6
Vas [l] 77,88
Vas [ft3] 2,75
Vd [l] 0,245
Vd [ft3] 8,64E-03
Sd [m2] 5,20E-02
Sd [ft2] 0,560
Revc [Ω] SINGLE 3.0
Levc [mH] (2000Hz) 2,390
Xmax [mm] 4,7
Xmax [in] 0,19
Zmax [Ω] 40,9
BI [Tm] 10,39
Rms[Ns/m] 2,010
Mms [g] 149,50
Cms [m/N] 2,100E-04
Mg.Wt.[g] 940
Flux Density [Gauss] 6210
Hag [mm] 6
Hag [In] 0,236
Hvc [mm] 15,5
Hvc [In] 0,610
VC.Diameter [mm] 40
Eff [%] 0,21
S.P.L. [dB] 95,0
R.M.S.Power [W] 300
M.M.P. [W] 1300
Sp. Displacement [l] 1,66
Sp. Displacement [ft3] 0,059
Recom. Enclosure [l] 35,4
Recom. Enclosure [ft3] 1,25
F0 (in Cabinet) 51,2
Q0 (in Cabinet) 1,252
 Filesize:  169.88 KB
 Viewed:  287 Time(s)
 Filesize:  203.88 KB
 Viewed:  270 Time(s)
julyo13
Data înscrierii: 09/Mar/2011
Locație: Vatra Dornei
MesajTrimis: Lun Aug 20, 2012 7:44 pm    Titlul subiectului: Răspunde cu citat (quote)
Eu as alege JL AUDIO...Bafta!!!!!!
ATOMIC 1000.1 D+2 ROCKFORD FOSGATE HE 12''
Keno
MesajTrimis: Lun Aug 20, 2012 7:48 pm    Titlul subiectului: Răspunde cu citat (quote)
Merci, JL as vrea si eu sa cumpar doar ca celor de la Be-loud nu le mai furnizeaza produsele JL. Si nu mai prea gasesc JL-ul la pretul asta.
julyo13
MesajTrimis: Lun Aug 20, 2012 7:56 pm    Titlul subiectului: Răspunde cu citat (quote)
Are cineva la vanzare dar de 150 w RMS..Bafta!!!
JARRELL
Data înscrierii: 23/Mar/2011
Locație: TG JIU
MesajTrimis: Lun Aug 20, 2012 8:24 pm    Titlul subiectului: Răspunde cu citat (quote)
Diful. Pioneer are EBP sub 50, deci va da rezultate doar in incinta inchisa; JL-ul poti sa-l folosesti in incinta bass reflex, dar tot o incinta inchisa i s-ar potrivi mai bine.
Keno
MesajTrimis: Lun Aug 20, 2012 9:08 pm    Titlul subiectului: Răspunde cu citat (quote)
Ai dreptate, am calculat si eu EBP-urile... oricum niciunul dintre difuri nu se mai gaseste pe be-loud.
Am ajuns la un TS-W257D2 sau un TS-W257D4, insa e un pic de dilema aici pentru ca nu inteleg cum sta treaba cu ohmii si bobinele.
Vad ca cel de 2 ohmi se poate lega asa: The TS-W257D2 offers you a variety of set-up possibilities (4Ω or 1Ω)
iar cel de 4 ohmi se poate lega asa The TS-W257D4 offers you a variety of set-up possibilities (8Ω or 2Ω)
Deci sa inteleg ca la cel de 2 ohmi nu-l pot lega numai pe 1ohm sau 4 ohmi iar pe cel de 4 ohmi il pot lega pe 8 sau doi ohmi... si in acest caz ar fi mai bun cel de 4 incat pot sa il leg la amplif pe 2 ohmi? Confused
Cat despre EBP la unul e aproape 70 iar la celalalt e 74, deci merg pe reflex.
JARRELL
Locație: TG JIU
MesajTrimis: Lun Aug 20, 2012 9:44 pm    Titlul subiectului: Răspunde cu citat (quote)
Cel cu 2 bobine de 2 ohmi poti sa-l folosesti la 1 sau 4 ohmi in functie de cum legi bobinele ( paralel sau serie); daca amplificatorul tau suporta o impendanta de minim 2 ohmi si vrei sa-l folosesti in acest mod, atunci subul cu 2 bobine de 4 ohmi poti sa-l folosesti la 2 ohmi prin legarea in paralel a bobinelor.
Keno
MesajTrimis: Lun Aug 20, 2012 10:11 pm    Titlul subiectului: Răspunde cu citat (quote)
Conteaza si daca e cu 2 canale sau e monobloc ampliful?
De exemplu daca e unul de 2 canale
4 ohmi: 2 x 75 W RMS
2 ohmi: 2 x 110 W RMS
sau daca e unul monobloc
225W RMS x 1 la 4 ohmi
360W RMS x 1 la 2 ohmi
Care ar fi diferentele si care woofer la care amplicifator s-ar potrivi mai bine, sau cum trebuie legate?
