vand statii(audison,magnat),difuzoare,subwoofer
tziboo
Data înscrierii: 25/Ian/2010
Locație: harlau-iasi
MesajTrimis: Mar Aug 17, 2010 10:19 pm    Titlul subiectului: vand statii(audison,magnat),difuzoare,subwoofer Răspunde cu citat (quote)
din cauza ca am un fratior asa de bun si destept a facut accident cu masina mea... am scos ce a mai ramas intreg din ea:
4 buc difuzoare :
Well Woofer 30CM 400W, CS30W-W:
de 300mm
magnet de 1417 grame
cos din otel shtantzat, extra greu
borne aurite
putere: max. 400 watt (nu prea cred)
banda frecventza: 25-2.000 Hz
impedanta: 4 Ohm
PARAMETRII:
Revc: 3.6 Ohm
Erm: 0.856
Mms: 77.853 g
Qts: 0.361
Fo: 35.2 Hz
BL: 12.418 Tm
No: 1.099%
Sd: 0.053 m patrati
Cms: 234.745u M/N
Qms: 2.386
SPL: 92 dB
Krm: 2.1354 Ohm
Mmd: 70.837m Kg
Qes: 0.425
-----------------------100lei bucata
un Amplificator Auto Magnat Ultra 4000 :
Magnat Ultra 4000
Amplificator stereo 4 canale
Putere reala 4 ohmi RMS 4x45
Putere reala 2 ohmi RMS 4x140
Putere reala in punte 2x130W
Raspuns in frecventa 5Hz - 60kHz
Bass Boost variabil
Filtre low-pass si high-pass variabile
Protectie la: suprasarcina, supraincalzire, scurt-circuit
-----------------------------250lei
si inca 2 bucati amplicatoare audison lr72
LR 72
TECHNICAL DATA
POWER SUPPLY 11 Ă· 15 VDC
IDLING CURRENT 0.8 A
MAX CONSUMPTION (Nominal Pwr) 14 A
MAX DYNAMIC POWER (2 Ch x 4 Ohms) 75 W
MAX DYNAMIC POWER (1 Ch x 4 Ohms) Bridge 225 W
CONT. NOMINAL POWER (Tol. +10%; -5%)
2 Ch x 4 Ohms; 0.3% THD; 12 VDC 45 W (RMS)
CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 50 W (RMS)
CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 75 W (RMS)
MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 150 W (RMS)
DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.07 %
BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz Ă· 100 KHz
DAMPING FACTOR (4 Ohms) 150
RISE TIME 4.5 μS
SIGNAL / NOISE RATIO 98 dBA
INPUT SENSITIVITY 0.3 V Ă· 4 VRMS
INPUT IMPEDANCE 15 KOhms
LOAD IMPEDANCE Stereo 8 - 4 - 2 Ohms
LOAD IMPEDANCE Mono 8 - 4 Ohms
REMOTE IN 7 Ă· 15 VDC
DIMENSIONS (WxHxD) 175 x 50 x 290 mm (6.88 x 1.96 x 11.41 inch)
LR 72
-------------------150leibucata
cd-player pioneer deh-p7500mp foarte destept si bun Wink
-----------------------220lei sau schimb cu lumina disco
un Subwoofer auto pasiv MAGNAT EDITION T30 , Tub bas reflex
Diametru difuzor joase (inch): 12
Numar cai: 1
Putere garantata (W): 300 W
Raspuns in frecventa (Hz): 19 - 200 Hz
Sensibilitate (dB): 95
Impedanta (Ohm): 4
200lei Wink Arrow
PS: difuzoarele +cd-playerul+ statia magnat au 4 luni de functionare Crying or Very sad
relatii la 0753334069 sau add la tziboo91 NU PREA FRECVENTEZ FORUMUL Rolling Eyes
plec pe marte
Ultima modificare efectuată tziboo la Vin Aug 20, 2010 11:50 am, modificat de 2 ori în total
tziboo
MesajTrimis: Mie Aug 18, 2010 2:08 pm    Titlul subiectului: Răspunde cu citat (quote)
cd-playerul sa dat Rolling Eyes rstul uup
plec pe marte
tziboo
MesajTrimis: Vin Aug 20, 2010 11:51 am    Titlul subiectului: Răspunde cu citat (quote)
uup preturile sunt negociabile Rolling Eyes
plec pe marte
Sharkky
Data înscrierii: 11/Mar/2007
MesajTrimis: Vin Aug 20, 2010 1:48 pm    Titlul subiectului: Răspunde cu citat (quote)
Usor cu Up-ul ... la Regulament zice de 7 zile ...
tziboo
MesajTrimis: Mie Aug 25, 2010 3:53 pm    Titlul subiectului: Răspunde cu citat (quote)
un amplificator audison lr72 a plecat spe bihor restul up Twisted Evil
plec pe marte
tziboo
MesajTrimis: Sâm Aug 28, 2010 10:33 am    Titlul subiectului: Răspunde cu citat (quote)
preturile scad
daca se cumbara o pereche de difuzoare las la 90lei buc daca se iau toate 4 las la 80 lei
statia magnat 230lei
statia audison 130 lei
subwooferul magnat 180 lei
plec pe marte
tziboo
MesajTrimis: Joi Sep 02, 2010 10:04 am    Titlul subiectului: Răspunde cu citat (quote)
Rolling Eyes
plec pe marte
