tziboo
Data înscrierii: 25/Ian/2010 Mesaje: 19 Locație: harlau-iasi
Trimis: Mar Aug 17, 2010 10:19 pm Titlul subiectului: vand statii(audison,magnat),difuzoare,subwoofer |
din cauza ca am un fratior asa de bun si destept a facut accident cu masina mea... am scos ce a mai ramas intreg din ea:
4 buc difuzoare :
Well Woofer 30CM 400W, CS30W-W:
de 300mm
magnet de 1417 grame
cos din otel shtantzat, extra greu
borne aurite
putere: max. 400 watt (nu prea cred)
banda frecventza: 25-2.000 Hz
impedanta: 4 Ohm
PARAMETRII:
Revc: 3.6 Ohm
Erm: 0.856
Mms: 77.853 g
Qts: 0.361
Fo: 35.2 Hz
BL: 12.418 Tm
No: 1.099%
Sd: 0.053 m patrati
Cms: 234.745u M/N
Qms: 2.386
SPL: 92 dB
Krm: 2.1354 Ohm
Mmd: 70.837m Kg
Qes: 0.425
-----------------------100lei bucata
un Amplificator Auto Magnat Ultra 4000 :
Magnat Ultra 4000
Amplificator stereo 4 canale
Putere reala 4 ohmi RMS 4x45
Putere reala 2 ohmi RMS 4x140
Putere reala in punte 2x130W
Raspuns in frecventa 5Hz - 60kHz
Bass Boost variabil
Filtre low-pass si high-pass variabile
Protectie la: suprasarcina, supraincalzire, scurt-circuit
-----------------------------250lei
si inca 2 bucati amplicatoare audison lr72
LR 72
TECHNICAL DATA
POWER SUPPLY 11 Ă· 15 VDC
IDLING CURRENT 0.8 A
MAX CONSUMPTION (Nominal Pwr) 14 A
MAX DYNAMIC POWER (2 Ch x 4 Ohms) 75 W
MAX DYNAMIC POWER (1 Ch x 4 Ohms) Bridge 225 W
CONT. NOMINAL POWER (Tol. +10%; -5%)
2 Ch x 4 Ohms; 0.3% THD; 12 VDC 45 W (RMS)
CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 50 W (RMS)
CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 75 W (RMS)
MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 150 W (RMS)
DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.07 %
BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz Ă· 100 KHz
DAMPING FACTOR (4 Ohms) 150
RISE TIME 4.5 μS
SIGNAL / NOISE RATIO 98 dBA
INPUT SENSITIVITY 0.3 V Ă· 4 VRMS
INPUT IMPEDANCE 15 KOhms
LOAD IMPEDANCE Stereo 8 - 4 - 2 Ohms
LOAD IMPEDANCE Mono 8 - 4 Ohms
REMOTE IN 7 Ă· 15 VDC
DIMENSIONS (WxHxD) 175 x 50 x 290 mm (6.88 x 1.96 x 11.41 inch)
LR 72
-------------------150leibucata
cd-player pioneer deh-p7500mp foarte destept si bun
-----------------------220lei sau schimb cu lumina disco
un Subwoofer auto pasiv MAGNAT EDITION T30 , Tub bas reflex
Diametru difuzor joase (inch): 12
Numar cai: 1
Putere garantata (W): 300 W
Raspuns in frecventa (Hz): 19 - 200 Hz
Sensibilitate (dB): 95
Impedanta (Ohm): 4
200lei
PS: difuzoarele +cd-playerul+ statia magnat au 4 luni de functionare
relatii la 0753334069 sau add la tziboo91 NU PREA FRECVENTEZ FORUMUL  _________________ plec pe marte
Ultima modificare efectuată tziboo la Vin Aug 20, 2010 11:50 am, modificat de 2 ori în total |
tziboo
Trimis: Mie Aug 18, 2010 2:08 pm Titlul subiectului: |
cd-playerul sa dat rstul uup _________________ plec pe marte |
tziboo
Trimis: Vin Aug 20, 2010 11:51 am Titlul subiectului: |
uup preturile sunt negociabile  _________________ plec pe marte |
Sharkky Audiofil
Trimis: Vin Aug 20, 2010 1:48 pm Titlul subiectului: |
| Usor cu Up-ul ... la Regulament zice de 7 zile ... |
tziboo
Trimis: Mie Aug 25, 2010 3:53 pm Titlul subiectului: |
un amplificator audison lr72 a plecat spe bihor restul up  _________________ plec pe marte |
tziboo
Trimis: Sâm Aug 28, 2010 10:33 am Titlul subiectului: |
preturile scad
daca se cumbara o pereche de difuzoare las la 90lei buc daca se iau toate 4 las la 80 lei
statia magnat 230lei
statia audison 130 lei
subwooferul magnat 180 lei _________________ plec pe marte |
tziboo
Trimis: Joi Sep 02, 2010 10:04 am Titlul subiectului: |
