Ajutor Incinta HCCA 15.2
phalemi24
Data înscrierii: 03/Apr/2011
Locație: Piatra Neamt
MesajTrimis: Vin Aug 26, 2011 10:49 am    Titlul subiectului: Ajutor Incinta HCCA 15.2 Răspunde cu citat (quote)
Salutare din nou la toata lumea!
A ajuns in sfarsit si difuzorul meu de peste hotare...foarte masiv imi place la nebunie cum arata...are undeva la 35 kg...din pacate n-am avut cum sa-l probez ca nu am nici cutie si nici amplificator.pana mai strang bani de amplificare vreau sa-mi fac cutia...
am dimensiunile date de producator dar cred k e acordata undeva la 38hz....eu voiam sa o acordez undeva pe la 28-30 hz...
Citat:
SPECIFICATIONS
Model/Part Number HCCA152
Size 15”
Thiele/Small Parameters
Fs (free-air resonance, Hz) 28.13
Vas (equivalent compliance, cu. ft.) 2.95746
Vas (equivalent compliance, liters) 83.78
Qms (Q, mechanical) 5.17
Qes (Q, electrical) **** 0.55
Qts (total driver Q) **** 0.5
Re (DC resistance, ohms) **** 4
Z (nominal impedance, ohms) 2 x 2
Le (inductance, mh) **** 2.59
Efficiency (1W @ 1M, dB) 87.2
Xmax (one way linear excursion, in.) 1.18939
Xmax (one way linear excursion, mm) 30.18
Pe (continuous power handling, watts) 2000
Peak power handling (music, watts) * 4000
Mms (total moving mass, grams) 500
Cms(mechanical compliance mm/N) 0.00005
Bl (motor strength, Tesla-M) 25.34
Sd (effective radiating area, sq. cm.) 962.11
Sd (effective radiating area, sq. in.) 149.13
Frequency range (Hz) 21 - 100
Energy Bandwidth Product (EBP) ** 51
Driver Physical Dimension
Speaker Displacement (cu ft) 0.37704
Speaker Outer Diameter(inches/mm) 383
Mounting Hole Diameter(inches/mm) 15.079
Mounting Depth(inches/mm)11.575/294
Magnet Weight (Oz) 444.98
Recommended Enclosures
Typical sealed enclosure (cu. ft.) 3.64
Vented enclosure (cu. ft.) *** 3.05
Port tuning frequency (Hz) 38
Port square equivalent (inches) 16 x 3
Port length (inches) 26.62
dak ma poate ajuta cineva cu niste dimensiuni incinta...as fi recunoscator.
si din ce ar fi recomandat sa se faca o incinta?
dimensiuni producator
 Filesize:  94.41 KB
 Viewed:  333 Time(s)
"Hi-Fi" or "No-Fi" !
phalemi24
MesajTrimis: Mie Aug 31, 2011 10:24 am    Titlul subiectului: Răspunde cu citat (quote)
nici o sugestie?
Mihai Cimpoeru
Data înscrierii: 03/Mar/2011
MesajTrimis: Mie Aug 31, 2011 1:22 pm    Titlul subiectului: Răspunde cu citat (quote)
Din parametri el e facut pentru cutie inchisa , dar merge si in basreflex .
In cutia recomandata recomandata de producator ai o galma de vreo 5 db la 45 hz, dar daca cobori acordajul la 28 hz e mai liniar si f3 coboara de la 31 hz ( acordaj la 38 hz ) pana pe la 27 ( acordaj 28 hz ) .
Problema e ca la aceeasi latime respectiv inaltime a portului lungimea lui ajunge la 120 cm . Laughing
phalemi24
MesajTrimis: Vin Sep 09, 2011 10:08 am    Titlul subiectului: Răspunde cu citat (quote)
da...port lung de 1 m 20cm mai greu... Very Happy
si daca ar fi sa modific dimensiunile cutiei....cam de ce lucru sa tin cont?
un soft ceva de calculat dimensiunile portului imi puteti recomanda?
costy_suceava
Data înscrierii: 15/Oct/2009
Locație: suceava
MesajTrimis: Vin Sep 09, 2011 11:39 am    Titlul subiectului: Răspunde cu citat (quote)
pune poze cu diful Very Happy
phalemi24
MesajTrimis: Vin Sep 09, 2011 2:35 pm    Titlul subiectului: Răspunde cu citat (quote)
o sa pun ceva poze cand ajung acasa...acum sunt la servici. Smile
phalemi24
MesajTrimis: Vin Sep 09, 2011 6:43 pm    Titlul subiectului: Răspunde cu citat (quote)
cateva poze...
 Filesize:  99.37 KB
 Viewed:  313 Time(s)
 Filesize:  109.07 KB
 Viewed:  288 Time(s)
 Filesize:  118.27 KB
 Viewed:  268 Time(s)
 Filesize:  125.31 KB
 Viewed:  301 Time(s)
Un difuzor fff masiv, 12 kg numai magnetul :D
 Filesize:  131.2 KB
 Viewed:  310 Time(s)
 Filesize:  109.81 KB
 Viewed:  280 Time(s)
costy_suceava
Locație: suceava
MesajTrimis: Sâm Sep 10, 2011 1:32 am    Titlul subiectului: Răspunde cu citat (quote)
frumos! sa l asculti cu placere!
keddy_net
Data înscrierii: 27/Oct/2007
MesajTrimis: Mar Sep 13, 2011 9:34 pm    Titlul subiectului: Răspunde cu citat (quote)
cat te-a costat, de unde l-ai luat, din ce tara, cat a fost transport, comision?
tare curios as fi sa vad cum se aude, mai ales ca si eu vreau sa imi aduc 'de peste hotare' ceva tare.
legat de incinta, te ajut eu sa o calculezi cu bass box, dar saptamana viitoare, da-mi add daca vrei sa te ajut mihai.keddy
salut!
phalemi24
MesajTrimis: Vin Oct 07, 2011 8:50 pm    Titlul subiectului: Răspunde cu citat (quote)
@keddy_net: pai am cautat pe internet un reprezentant local al firmei ce produce wooferul(Directed Electronics), si am dat de Falcon Electronics...am sunat si mi s-a spus la inceput ca nu mai sunt reprezentanti , insa probabil au contactat pe aia din state(de acolo a venit) si mi-au trimis o lista de preturi.coletul a ajuns in 15 zile lucratoare, m-a costat 1700 RON wooferul +@50 ron transportul prin fan courier(are 40 kg!!).o sa iti dau un add maine in lista si ne auzim pe mess Wink
@costy_sv: ms Smile mai am ceva de munca pana il pun in functiune dar presimt ca o sa merite.
am mai adaugat si cateva poze...de unde am plecat si continuarea Very Happy
 Filesize:  112.51 KB
 Viewed:  267 Time(s)
 Filesize:  103 KB
 Viewed:  287 Time(s)
 Filesize:  86.75 KB
 Viewed:  284 Time(s)
 Filesize:  94.47 KB
 Viewed:  251 Time(s)
 Filesize:  93.21 KB
 Viewed:  267 Time(s)
 Filesize:  104.21 KB
 Viewed:  306 Time(s)
 Filesize:  69.77 KB
 Viewed:  278 Time(s)
keddy_net
MesajTrimis: Sâm Oct 08, 2011 11:41 am    Titlul subiectului: Răspunde cu citat (quote)
astept sa vb mai multe, ti-am zis ca vreau sa aduc si eu ceva. Bafta !
phalemi24
MesajTrimis: Mie Noi 02, 2011 4:29 pm    Titlul subiectului: Răspunde cu citat (quote)
care ar fi cea mai buna varianta dintre aceste 2 incinte ca si acordaj?
 Filesize:  177.63 KB
 Viewed:  307 Time(s)
Pigoo
Data înscrierii: 08/Oct/2008
Locație: Constanta
MesajTrimis: Mie Noi 02, 2011 6:24 pm    Titlul subiectului: Răspunde cu citat (quote)
100L intern fara difuzor si port, iar acordajul dupa gusturi , vrei bas mai moale.. mai cald.. mai tare, mai impins.. fiecare cu ale lui , daca ar fi dupa mine i-as pune 35-38hz, dupa parerea mea acolo suna cel mai ok bass reflexu pe orice gen muzical .
daca nu asculti hip hop excesiv nu are rost sa cobori mai mult de 35hz .
phalemi24
MesajTrimis: Vin Noi 18, 2011 7:54 pm    Titlul subiectului: Răspunde cu citat (quote)
Cred ca o sa fac pentru inceput o cutie undeva la 32Hz sa vad cum suna...
Deci ideea ar fi cutia sa aiba ~100l fara dif si port. Mc de raspuns Pigoo!
Daca are altcineva opinii sau sugestii(chiar si niste dimensiuni pt cutie daca se poate Smile) astept nerabdator Wink
Stima!
Pigoo
Locație: Constanta
MesajTrimis: Vin Noi 18, 2011 8:36 pm    Titlul subiectului: Răspunde cu citat (quote)
inca o chestie, daca tot esti chitit pe cutie . placa unde o sa fie pus difuzorul, ce latime are?
40cm ?
in orice caz.. vezi sa portul sa nu aibe latime mai mica de 12cm , iar inaltimea o lasi pe aceea a placii .. adica un minim de 12cm x 40cm ar fi ok.. tinand cont de acordarea pe care vrei sa o faci, ca sa nu auzi fluiere prin spate Laughing
oricum.... o sa iasa o ditamai cutia, portul cred ca o sa aibe cam 150cm lungime Shocked
si inca o chestie, daca vrei acordaj asa jos.. recomand sa mai adaugi 20L la cei 100L .
